RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU
2 posters
RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU Empty RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU
Post by raymond88 Fri Jul 22, 2016 1:37 am
Item: RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU. This model is practically the  '+' version except for the casing etc.
Condition: Item is in excellent working condition. Comes with original cable.
This was the original Symphono that have a separate power supply.  It have both RCA and XLR balance outputs. Sounds clean, transparent and dynamic.
Price: RM2500 RM2300 RM2150 or swap/topup
New was RRP £1250
Front view
RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU Cleara10
Rear View
RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU Cleara12
PSU
RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU Cleara11
Technische Daten - Technical Data:
Verstärkung bei 1 kHz: 60 dB MC-Betrieb/Mode
Eingangsimpedanz: 500 Ohm/270pF
Input load:
Schneidekennlinien-EntzerrungNach RIAA (Zeitkonstanten:
RIAA75μs / 318μs / 3180μs)
RIAA Genauigkeit: ± 0,1 dB
RIAA accuracy:
Klirrfaktor: < 0,004% (IEC A)
THD:
Signal Rauschabstand: > 65 dB
S/N:
Übersprechdämpfung: > 95 dB bei 1 kHz,
Channel seperationgegenüberliegender Kanal
kurzgeschlossen
Maximale Ausgangsspannung: 12 V (1 kHz)
Max. output voltage:
Rumpelfiltereinsatz: 20 Hz; Steilheit -6 dB / Oct.
Subsonic filter: (Brücke gezogen / Bridge removed)
Spannungsversorgung: ± 25V DC
Power supply: (externes NetzteilKunststoffgehäuse)
(external power supply)
AusgängeSymmetrisch (XLR) und
Outputs: asymmetrisch (CINCH)
Gewicht: 1.460 g (Vorverstärker und Netzteil)
Weight: (Preamp and power supply)
Abmessungen ( b x t x h ): 150mm x 175mm x 54mm
Dimensions ( l x h x d ):
Number of posts : 9985
RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU Empty Re: RARE Clearaudio - Symphono MC Phono stage Dual Mono - Balanced & Unbalanced outputs + Original Clearaudio External PSU
Post by raymond88 Fri Jul 29, 2016 4:08 pm
Post by raymond88 Sat Aug 06, 2016 10:28 am
price reduced
Post by raymond88 Thu Aug 18, 2016 1:09 pm
Post by raymond88 Mon Aug 29, 2016 4:31 pm
bump with price reduced
Post by raymond88 Mon Sep 12, 2016 4:45 pm
Post by raymond88 Sun Sep 25, 2016 11:14 pm
Post by skfong Sun Sep 25, 2016 11:27 pm
open to trade with my VTL preamp?
http://skfong.blogspot.sg/2015/07/fs-vtl-integrator-serial-169.html
skfong
skfong
Number of posts : 472
Registration date : 2010-04-19
http://skfong.blogspot.com/
