Choseal Flat Speaker Wire
Post by cssam5229 on Wed Aug 10, 2016 10:10 am
Choseal audio speakers line made a superb wire process, from imported PVC, oxygen-free copper inside (OFC) conductor & aerospace grade polyethylene (LDPE) / PVC insulation,
The high-fidelity design with anti-interference ability to enhance the transmission signal by using good effect and easy to use soft wire. Widely used in home decoration, audio-visual equipment connection, engineering, installation, car audio, electronic fields and so on.
Can be used for both front speaker or surround speaker wire.
The advantage of this flat speaker wire is that it makes excellent surround speaker wire and can easily fix in place using even double sided tape on walls or floor.
Product Name: Choseal Q-170
Type: Flat speaker wire 99.99% OFC copper
Conductor : (22 strands/ each * 4C) oxygen-free copper * 2C
Jacket: PVC Outer Diameter (OD) 12.8mm * 2.2mm thick paintable
Length: 100 m
Printing : There is printing on the speaker wire jacket to indicate the length.
Color: Yellowish White
This wire have an equivalent gauge of AWG 14 making it excellent choice for superb audio performance over most other brands in the market which have higher gauge of AWG 16 and above. Lower AWG means thicker copper wire means better performance over long cable run.
Why pay more for equivalent performance cable? Get equivalent performance cable without burning holes in your pocket.
To read more on Choseal company visit here
Contact : (Whatsapp or SMS) : 0122163733
Serious buyer only.
Kindly make appointment with me if interested.
Item Location : Subang Shah Alam
Price : RM6 per meter for loose buy
Price for 1 roll (100m) : RM550 (works out RM5.50 per meter)
Can sell in your required cut length based on the price per meter as above
Quick grab now selling fast only last roll of 100m available.
cssam5229
Number of posts : 670
Registration date : 2015-05-06
Re: Choseal Flat Speaker Wire
Post by cssam5229 on Tue Aug 23, 2016 10:50 am
cssam5229
Post by cssam5229 on Wed Aug 31, 2016 12:58 pm
cssam5229
Post by cssam5229 on Fri Sep 09, 2016 3:57 pm
cssam5229
Post by cssam5229 on Sat Sep 17, 2016 7:39 pm
cssam5229
Post by cssam5229 on Fri Oct 14, 2016 11:58 am
cssam5229
Post by cssam5229 on Fri Oct 21, 2016 10:05 pm
cssam5229
Post by cssam5229 on Sat Oct 29, 2016 9:26 am
cssam5229
Post by cssam5229 on Mon Nov 07, 2016 9:49 pm
cssam5229
Post by cssam5229 on Thu Nov 17, 2016 10:51 pm
cssam5229
Post by cssam5229 on Sat Jan 07, 2017 1:34 pm
cssam5229
Post by cssam5229 on Sat Jan 14, 2017 3:20 pm
cssam5229
Post by cssam5229 on Mon Jan 23, 2017 12:48 pm
cssam5229
Post by cssam5229 on Wed Feb 01, 2017 1:32 am
cssam5229
Post by cssam5229 on Thu Feb 09, 2017 9:54 am
cssam5229
Post by cssam5229 on Sat Feb 18, 2017 12:43 pm
cssam5229
Post by cssam5229 on Sun Feb 26, 2017 12:44 am
cssam5229
Post by cssam5229 on Sun Mar 05, 2017 11:06 am
cssam5229
Post by cssam5229 on Sun Mar 12, 2017 12:05 pm
cssam5229
Post by cssam5229 on Sat Mar 25, 2017 5:59 pm
cssam5229
Post by cssam5229 on Fri Apr 07, 2017 6:14 pm
cssam5229
Post by cssam5229 on Sun Apr 16, 2017 6:22 pm
cssam5229
Post by cssam5229 on Thu Apr 27, 2017 11:14 pm
cssam5229
Post by cssam5229 on Sat May 06, 2017 4:19 pm
cssam5229
Post by cssam5229 on Fri May 19, 2017 9:45 am
cssam5229
Post by cssam5229 on Fri May 26, 2017 9:52 am
cssam5229
Post by cssam5229 on Sat Jun 24, 2017 6:00 pm
cssam5229
Post by cssam5229 on Thu Jul 13, 2017 11:29 pm
cssam5229
Post by cssam5229 on Sun Jul 30, 2017 12:04 pm
cssam5229
Post by cssam5229 on Fri Aug 11, 2017 10:56 pm
cssam5229
Post by cssam5229 on Fri Aug 18, 2017 9:58 am
cssam5229
Post by cssam5229 on Fri Aug 25, 2017 10:03 pm
cssam5229
Post by cssam5229 on Fri Sep 01, 2017 5:28 pm
cssam5229
Post by cssam5229 on Fri Sep 08, 2017 11:34 pm
cssam5229
Post by cssam5229 on Sat Sep 16, 2017 1:11 am
cssam5229
Post by cssam5229 on Sat Sep 23, 2017 12:38 am
cssam5229
Post by cssam5229 on Sat Sep 30, 2017 12:05 am
cssam5229
Post by cssam5229 on Sat Oct 07, 2017 12:09 am
cssam5229
