Yamaha A-S701 stereo integrated amplifier
Post by alfredce6333 on Sat Aug 20, 2016 4:07 pm
Yamaha A-S701 stereo integrated amplifier brand new, now selling at RM2899.
Hifi4sale friends please call for best price..
It's not hard to find an amplifier that will promise 100 watts per channel of power. But few amps can match that number with such incredibly low distortion as the Yamaha A-S701. This well-built integrated amplifier offers plenty of power to drive bookshelf or tower speakers, including more demanding loads. As you turn up the volume, this amp's anti-resonance construction, symmetrical circuit layout, and high-quality components ensure your music remains clean and clear. By minimizing distortion and interference, your music will sound more listenable with fine details shining through.
Features
High sound quality circuit design based on the ToP-ART (Total Purity Audio Reproduction Technology) concept
ToP-ART Design and ART Base Ensure Optimum Sound When processing and transmission of the audio signal is simple and direct there is less chance of it being affected by noise and distortion. Yamaha’s amplifier design technology called ToP-ART features an I/O (input to output) Direct Symmetrical Design, with left and right channels organised in a straight, symmetrical layout for highest signal purity. In addition, the ART (Anti-Resonance and Tough) Base bottom chassis and a solid centre bar provide high-rigidity support and vibration damping. These Yamaha design innovations contribute to this amplifiers’ rich audio reproduction with abundant musicality.
High Quality Parts for Outstanding Audio Performance
Custom-made power transformer, custom-made block capacitors, two direct signal path speaker relays, one-point grounding system, aluminium-extruded heat sinks and other top-quality parts effortlessly handle demanding audio signal conditions. The quality of each individual part, as well as how they work together, basically determines the sound quality of any component. Yamaha uses only very high quality parts, carefully selected and tested.
Created by Yamaha's Rich Experience and Tradition, and High Technological Expertise
Yamaha, with a long history of over 125 years as a musical instrument maker, also has a high reputation for HiFi components. The A-S701 is created by taking advantage of this rich experience and high technological expertise. Based on the concept of “Natural Sound”, for reproducing all music as it really sounds, and built with scrupulous care from circuit design to basic sound production, even though an entry model it reproduces high sound quality and musically rich sound.
CD Direct Amplification and Pure Direct Mode for Greater Sound Purity
With a straight connection to the CD input, CD Direct Amplification maximises CD source S/N ratio. Additionally, engaging the Pure Direct mode causes the music signals to travel the shortest possible circuit route, bypassing the buffer amp and the tone, loudness and balance controls to virtually eliminate any signal degradation for the purest sound quality.
Continuously Variable Loudness Control
The A-S701 also feature a new analogue loudness control on the front panel that uses electronic volume for higher sound quality, which lets you adjust the loudness effect as desired. Separate from the overall volume, this controls the balance of the low- and high- frequency sounds, providing full tonal range at any volume level, compensating for the natural loss in the human ear of high and low frequencies at soft levels.
Gold-plated Terminals
Gold-plated terminals ensure a high quality connection that prevents signal loss. The A-S701 have gold-plated speaker terminals and input terminals
Digital Audio Input for TV and/or Blu-ray Player
The A-S701 is equipped for digital audio input with both optical and coaxial terminals. The optical is for receiving audio from a TV, and the coaxial for receiving audio from a Blu-ray player. The audio stays in the digital domain, giving you pure, pristine dynamic sound for all your entertainment sources, from sports and other programmes to movies and concerts.
Connection for YBA-11 Bluetooth Wireless Adapter
With the YBA-11, you’ll be able to stream music wirelessly from a Bluetooth capable mobile phone or a PC to the Network receiver. Thanks to the digital connection and aptX® audio coding algorithm, you’ll enjoy wireless music streaming with optimum sound quality. You can also conveniently power the YBA-11 via the DC-out connection on the rear panel of the amplifier.
Speaker A, B or A+B Selection and Speaker Terminals for Two Systems
You can connect two separate speaker systems in different rooms and switch between them, or have them both playing at the same time. There are four terminals, so by just pushing a button, you can switch speakers to match the sound source.
Subwoofer Terminal
A terminal for connecting a subwoofer is provided, allowing you to increase the bass output of your system for a more powerful sound with better overall sound quality.
Phono MM Terminal
You can connect a turntable with an MM phono cartridge to play vinyl records. This lets you enjoy not only CDs, but also analogue record sound from an amp with the latest digital/analogue technology.
Simple yet Sophisticated Design
With a beautifully simple and unique design inherited directly from Yamaha’s HiFi audio components, this amplifier also boast an easy-to-operate button layout. The aluminium front panel has a richly textured silver hairline finish. The control knobs are also of the same luxurious construction as used on our top-end models.
Remote Control with Clean, Simple Design
The clean, simple design of the remote control provides easy-to-understand one-hand operation. The easy-to-use design makes it simple to adjust song volume and order. The unit has a sophisticated looking hairline finish that matches the design of the amplifiers. You can also use the remote to control a Yamaha CD player.
Rotary Encoder Input Selector with LEDs
The rotary encoder makes it quick and easy to select input sources. The luxury hairline finish material offers a nice tactile feeling. LEDs clearly show which source is selected, so you can easily switch sources even in a dark room.
Auto Power Standby Function
The amplifier has a power management function that detects when it hasn't been used for a long time (about 8 hours) even though the power is on, and automatically shifts it into standby mode. So even if you forget to turn it off, power consumption will be minimised.
Please visit our website to find out more products FOR SALE AT VERY SPECIAL PRICE
Interested please feel free to contact Lee 017-3116863
MONDAY - 10AM-8PM
TUESDAY - 10AM-8PM
THURSDAY - 10AM-8PM
FRIDAY - 10AM-8PM
SATURDAY - 10AM-8PM
We buy in your old items in cash!!
BRANDED led tv
amplifier
speaker
cd player
Specs
Receiver / Integrated Amplifier
[th]Minimum RMS Output Power (8 ohms, 20 Hz-20 kHz)[/th][th]Maximum Power (4 ohms, 1kHz, 0.7% THD, for Europe)[/th][th]High Dynamic Power/Channel (8/6/4/2 ohms)[/th][th]Damping Factor[/th][th]Frequency Response[/th][th]Total Harmonic Distortion (CD to Sp Out, 20 Hz-20 kHz)[/th][th]Signal-to-Noise Ratio (CD)[/th][th]Audio In / Out[/th][th]Digital Input[/th][th]Subwoofer Out[/th][th]DC out[/th][th]Pure Direct[/th][th]ToP-ART[/th]
100 W + 100 W (0.019% THD)
160 W + 160 W
140/170/220/290 W
240
10 Hz-100 kHz +/-1.0 dB
0.019% (50 W/8 ohms)
99dB (input shorted, 200 mV)
8 / 2
Yes (optical / coaxial)
Yes
Yes
Yes
Yes
[th]Switchable CD Direct Amplification[/th]
Yes
[th]Standby Power Consumption[/th][th]Power Management (Auto Power Standby)[/th][th]Dimensions (W x H x D)[/th][th]Weight[/th]
0.5W
Yes
435 x 151 x 387 mm; 17-1/8” x 6” x 15-1/4”
11.2 kg; 24.7 lbs.
Last edited by alfredce6333 on Sat Aug 20, 2016 4:26 pm; edited 1 time in total (Reason for editing : add images)
alfredce6333
Number of posts : 296
Registration date : 2016-04-08
