Accuphase E-600
Accuphase E-600
Post by Audioline on Sun Sep 11, 2016 10:09 pm
- Von Schweikert Audio
- PureAudio
- KR Audio
- TriangleART Turntable
- Endeavoraudio Audio
- Graham Audio
- Ensemble Audio
- Accuphase
- Cary Audio
- Rogers High Fidelity
- Sutherland (Phono Preamplifer)
- Audiodesk Vinyl Cleaner
- Artesania Audio (Rack)
- Zontek (Turntable / Tonearm / Phono Preamplifier)
- Mutech (Cartridge)
- Audio-Technica (Cartridge)
- The Wand (Tonearm)
- Glanz (Tonearm)
- Abis (Tonearm)
- ViV Laboratory Rigid Float Tonearm
Accuphase E-600
Recommended Retail Price: SGD$13,500.00
Aiming for the even higher performance level set by separate type amplifiers, the E-600 makes full use of the sophisticated design technology accumulated by Accuphase over the years. Featuring a further refined AAVA type volume control, latest circuit topology, and parts and materials of the highest grade, the E-600 is the non-plus-ultra integrated amplifier imbued with the spirit of the 40th anniversary commemorative models.
AAVA (Accuphase Analog Vari-gain Amplifier) volume control in the E-600 employs the same high-rigidity volume sensor, extruded from a solid aluminum block and featuring an ultra-massive brass shaft, originally developed for the models C-2820/C-2420. Operating the knob provides an utterly smooth operation feel. Paired with a drastic improvement in S/N ratio through low impedance circuit design, the E-600 takes both performance and build quality to a new level.
The power amplifier block is configured with the latest instrumentation amplifier topology, which enables fully balanced signal transmission throughout. Together with MCS+ and the current feedback amplification principle, this makes for even better electrical characteristics.
-Revolutionary AAVA volume control
- Output stage with triple parallel push-pull power MOS-FETs
- Instrumentation amplifier principle for power amplifier input stage allows fully balanced signal transmission, complemented by MCS+ topology and current feedback amplification circuitry
- Logic-control relays for shortest signal paths
- Strong power supply with massive high-efficiency transformer and large filtering capacitors
- POWER IN button allows separate use of preamplifier and power amplifier sections
- Numeric indication of volume level
- Continuous average output power: 120 W/ch (2 ohms), 60 W/ch (4 ohms), 30 W/ch (8 ohms)
- Frequency response (1 W output): 2 Hz - 150 kHz +0 -3,0 dB
- Damping factor: 500 (EIA 8 ohm, 50 Hz)
1 Orchid Club Road,
Social Clubhouse Unit #02-33B,
Orchid Country Club
Singapore 769162
Feeder bus every 15 mins from yishun mrt at taxi stand area
Whatsapp / Line +65 98353600
Sunday & Monday       1200 HRS to 1700 HRS
Tuesday to Saturday   1200 HRS to 1800 HRS
Audioline
Number of posts : 311
Registration date : 2010-01-23
http://www.audioline.com.sg
