Pioneer M-90 Reference Power Amplifier Stereo 200 Watts
Made In Japan
Power output: 200 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.003%
Input sensitivity: 1V
Signal to noise ratio: 125dB
Dimensions: 457 x 432 x 163mm
Weight: 27.3kg
Pioneer introduced the M-90 Reference Power Amplifier in 1987, to be used in conjunction with the C-90 Reference Control Amplifier. In the January 1987 issue of Stereo Review that ran the "Not Evolutionary-Revolutionary" advertisement, here is what Pioneer said about the M-90:
"The M-90 is a superb high-power stereo amplifier, utilizing dual-mono construction.
It is conservatively rated at 200 W/CH into 8 ohms and delivers 800 W/CH of dynamic power at 2 ohms.
The wide dynamic range of the digital sources can now be reproduced effortlessly, with any loudspeakers.
The M-90's high current capacity of 47 amps can handle the challenge of the most complex speaker loads.
To further enhance S/N ratio and channel separation, relay-operated electronic switches and a long shaft volume control keep the length of signal paths down to a minimum. Why include a high quality volume control on a power amp? To pursue the straight wire-with-gain philosophy when using a CD player connected directly.
Pure sound, redefined."
The M-90 was virtually distortion-free, having only 0.003% THD from 20-20K Hz @ 8 ohms, and had a S/N ratio of 125 dB!
the M-90 Reference Power Amplifier was a twin-mono design with separate power supplies and circuitry for both left and right channels
Price : RM 2450
- Number of posts : 2967
BUMP
UP
BUMP
Up
BUMP
UP
BUMP
BUMP
» Vintage Silver Pioneer C-73 Pre-Amplifier and SPEC2 250 Watts Power Amplifier ( Used)
» Bryston 4B ST Series 250 Watts XLR Stereo Power Amplifier
» Yamaha M-70 Stereo 200 Watts Per Channel Power Amplifier
» BGW 750G Stereo 375 watts per channel Professional Power Amplifier XLR input
» Vintage Bogen MO-200A Stereo 100 Watts Vacuum Tube Power Amplifier ( Used)
