Choseal LB-5108 OCC Audiophile Hi-Fi Speaker Cable
3 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Choseal LB-5108 Single Crystal OCC 6N Flagship audiophile Hi-Fi speaker wire with U-Plug.
Original factory pack includes four interchangeable banana plugs
Why OCC?
Used throughout the high end audio industry in most flagship cable products, OCC provides the superior quality copper and silver possible today.OCC (Ohno Continuous Cast) is the name given to the casting process developed Professor Ohno in Japan to help defeat annealing issues and virtually eliminate all grain boundaries in copper or silver with a unique patented process. The OCC casting method uses specialized heated moulds in order to draw a single crystal up to 125 meters in length.
With only a single crystal in very long lengths, there is an unimpeded free path for the best possible signal transfer. Along with this superior single long crystal structure, OCC provides copper and silver with the least possible oxides and other impurities.
In comparison to OCC, there are other lower grade coppers such as OFC with a multitude of grain boundaries and other impurities. OFC (Oxygen Free Copper) has around 400 crystals per foot and despite its name has an oxygen content of about 10 ppm. OFC has many grain boundaries per foot that the signal must route around and pass.
The question ultimately comes down to the following: Would you rather have your signal flow in a path with many cracks, bumps and obstacles in the way (OFC) or flow along a completely unimpeded free path with the lowest possible impurities (OCC). From our view the choice is simple, and the bottom line is most top cable designs utilize OCC as it gives the absolute purest base platform to get that much closer to true absolute transparency.
Brand: Choseal
Model No: LB-5108
Terminals: Imported high quality 24K gold-plated terminals
Length: 2.5 m
Outer Diameter : OD16mm
Packaging: Box
Material : Single crystal OCC copper weight about 2.5 kg
Features :
● 99.9999% 6N high purity OCC single crystal copper
● conductor spiral geometry design
● non-magnetic copper 24K gold-plated banana plugs
● low impedance & low distortion
Plug can be replace either U-shaped or banana plug.
Pack comes with 4 interchangeable banana plugs.
Very suitable for bi-wiring, 1 pair of wire can bi-wire 1 speaker.
Production of single crystal copper (referred to as the OCC) wire for sound, and is a major breakthrough in recent years, audio wire manufacturing. Scientific evidence: a high-purity single crystal copper is copper (purity up to 6N), its whole root of copper rod by only one or a few grains, no "boundary" or less between the grains and grain " grain boundaries " has a very high signal transmission performance.
In comparison, to the widely used production of oxygen-free copper audio cable (refer to OFC), a number of its internal grain "grain boundaries" can cause signal distortion, refraction/reflection and attenuation, resulting in signal transmission performance loss compare to the single crystal copper OCC cable.
Product Features:
Multi-Unit 6N OCC single crystal copper as conductor, screw geometry design, add in-line multi-strand nerves of the role played back, with the original 24K gold-plated lockable U-type plug, particularly strong bass playback and sharp dynamic of both advantages, sound particularly vivid. Under this line conductor can be notice, background is clean, open transparency, sound quality tends delicate, sweet, warm tone bias, smooth, the overall performance is easy, comfortable and never tiring.
Pay attention to connectors and plug of same colour when connecting
Notes :
1. Speaker cable input / output is"+" ----> "+", "-" ---->"-", the Red is "+", Black is "-".
2. The speaker cable is directional, and there is marked arrow indicating, amplifier ----> speaker . Follow this connection for best results.
Contact : (Whatsapp or SMS) : 0122163733
Serious buyer only. Kindly make appointment with me if interested.
Item Location : Shah Alam
Promotion Price Now!!! Limited Stock !!!
Price : RM450 per pair (2 pcs of cable),
(Free 4 pcs of interchangable banana plug inside box)
DEAL OPTIONS
Meet-Up Shah Alam Seksyen 22/Seksyen U5 Selangor Malaysia,
Weekday (Mon-Fri) : By appointment (9.30am to 11.00pm)
Weekend (Sat & Sun) : Time by appointment in advance
Mailing or Delivery
Please add in RM25 for poslaju postage charge within Peninsular Malaysia
Last edited by cssam5229 on Thu Sep 13, 2018 12:42 pm; edited 8 times in total (Reason for editing : text edit)
cssam5229- Frequent Contributor
- Number of posts : 1752
Registration date : 2015-05-06
Re: Choseal LB-5108 OCC Audiophile Hi-Fi Speaker Cable
hi, is this biwire only?
morpheuse- Club Member
- Number of posts : 26
Registration date : 2014-04-14
Source(s): Rega RP1, Rega Apollo
Amplification: QSC DCA 2422, Rega Phono, Krell 400xvi, SET tube amp
Speakers: Monitor Audio Studio 20
morpheuse wrote:hi, is this biwire only?
Hi thanks for your interest.
This is actually a single wiring speaker wire
There are 1 pair (2 pcs) of single wiring speaker wire inside the box.
So 1 pair is enough for wiring both your front speakers if you are using single
wiring configuration.
For bi-wiring you need to buy 2 pairs (4pcs) of these to do the bi-wring configuration.
Hopes this clarify your doubts.
If you interested please whataspp/sms/contact me at 0122163733.
Thanks
What is the gauge in awg?
klimal- Frequent Contributor
- Number of posts : 200
Registration date : 2009-11-11
Source(s): SLAT L75, OPPO 203D, Asus TinkerBoard / Topping D90
Amplification: LL9226 SUT, AHT Non Sig., EAR834 clone, BAT VK-3000SE, BAT VK150se, Emotiva XPA7 Gen3
Speakers: SB Acoustics Rinjani front main, DIY SBA Satori Center, , ELS3 sides Epos KI overheads. , Subwoofers SVS SB16Ultra, PC13Ultra
» Choseal LB-5108 Audiophile Speaker Cable (sold)
» Choseal LB5110 Audiophile Hi-Fi Speaker Cable
» Choseal (Qiuyeyuan) YF-218 Audiophile Speaker Cable
» Choseal speaker cable
Page 1 of 3
