VIMAK DT-600 CD Player
VIMAK DT-600 CD Player Empty VIMAK DT-600 CD Player
Post by HiFiLab on Tue Oct 18, 2016 9:21 am
VIMAK DT-600 CD Player Img_2155
VIMAK DT-600 CD Player Img_2156
VIMAK DT-600 CD Player Img_2157
VIMAK DT-600 CD Player Img_2158
VIMAK DT-600 CD Player Img_2159
VIMAK DT-600 CD Player Img_2160
VIMAK DT-600 CD Player Img_2161
Vimak DT-600 CD Player Features:
The DT-600 CD player is one of Vimak audio's products launched in 2006 and sold to the Asia-Pacific region.
Open the cover, you will find inside the machine, there are two special places, large transformers (for CD machine) and three black modules, carefully observed with a radiator module is "ASP" power module, the other two Is the signal output of the school sound module, the whole material is even more simple: the United States "Doni" resistance, Weimar, ROE, nichicon capacitors, PCM1792 digital filter and D / A chip, low-pass filter and I / 4 OPA2604 play, and read disc system uses PHILIPS lens enhanced movement and CD-Ⅱ servo circuit.
"ASP" power technology applications, to DT-600 provides an excellent power platform, so that the sound structure of the near-perfect: the background quiet, successfully eliminate the audio dye; well.  With the signal output of the school sound module, DT-600 voice performance, low frequency full dive and flexible, IF warm warmth and rich flavor, high-frequency extension of exquisite and rich texture, so you are listening to the United States enjoy each time.
Vimak DT-600 CD Player technology
1. "ASP" (independent power supply isolation) patented technology;
2. Multi-shock sound of school sound technology;
3. Customized optical lens reading system PHILIPS;
4. Can be upgraded online software features;
5.24Bit / 192KHZ format (PCM1792);
6. The analog signal has RCA and XLR output mode;
7. Digital signal has COXIAL and AES / EBU output mode;
8. Double array real dot matrix display;
稱霸數位訊源一時的Vimak,沈寂多年之後終於重現江湖,更棒的是:Vimak再也不是高不可攀的貴族,而是飛入尋常百姓家,走「高貴不貴」的平價路線。全新上市的Vimak DT-600 CD唱盤,外觀延續早年Vimak DT-1000轉盤與DS2000數類轉換器的線條簡化,搭配宛如註冊商標的飛梭,但功能略有不同,不過仍然一看就懷念起雄霸一時的Vimak。
過去Vimak以應用DSP技術聞名,不過在DT-600上面,則是採用了Burr Brown PCM1792解碼晶片,是目前動態範圍最高(127dB)的DAC晶片。為了提高轉盤的穩定度,Philips承盤系統還經過Vimak的精心強處理,提高阻尼以強化避震效果,並以鐵板隔絕噪訊,整個Philips機芯的底座並以厚重的鋁框固定。
DT-600並採用3只軍規石英震盪器,誤差值在5ppm以下,一顆用在主時鐘校正,另外兩顆用在濾波。從轉盤讀取、校正到數類轉換,DT-600可說是面面俱到。
而電源供應的部分,則是Vimak的新特點,採用獨家專利的ASP電源隔離自主供應技術,可以同步即時檢查電源負載變化,以提供高頻寬、低內阻與高精確度的穩壓供電。換句話說,ASP供電等於是在DT-600內部額外再裝上一部電源處理器。看來DT-600 CD唱盤不僅要重現Vimak數位王者的輝煌歷史,還以高規格的設計,加上難以置信的低價,搶佔「最超值CD唱盤」的王座!
你若是资深的发烧友,应该会记得十多年前,Vimak曾经在数码世界里叱咤风云,口碑之佳,堪与Wadia,Mark Levinson等名机相提并论。但世事难料,Vimak不知何故,仿佛风吹云散,了无痕迹地在江湖中销声匿迹。近来Vimak重整旗鼓,在龙的故乡设厂生产,推出了这一台价格平易近人、性能出众的新CD机。
当CD机横空降陆寒舍时,仔细端详机子后方,共有四种输出——RCA及Balance;数码输出则有Coaxial及AEX/EBU,如此完备的输出选择,厂方似乎有意再现十多年前高价机种的风范,瞄准更大的市场份额,潜意识中也略略感受到厂家的企图心。首先用上了小组合,Almarro A318B,配以Rogers LS 3/5a LE,听过了许多监听CD后,感觉DT600在人声部分,演绎效果颇讨人喜欢,质感丰富的中音,在道友们心中,绝对是重中之重,第一关就此轻易地通过。
倘若仔细欣赏,细分特质,其女声音色属于清淡朴素,但多了一份自然与慵懒,犹如一壶清茶、一缕清烟般地亲切与温馨,不似其他机种,刻意表现出女性的妩媚,或深情款款的浪漫与缠绵,此为一。
DT600在播放古典音乐时,无论是《新历其声》里的《摇篮曲》,或Summer Evening弦乐团的表现,整体音响恒定,音场垂直纵深,小提琴的音色朴素自然(也许有人称为中性),琴音丝丝入扣,淡淡的松香味,比例舒适,层次如舒云淡月,是一贯的音色,此为二。但对于讲究音色的朋友,似乎少了暗香浮动的贵气与娇艳。当然这是审美中的不同选择,准确与美感,已是千年古老的哲学命题,对发烧友来说,也许是不可承受的重。平心静思,只要你对自己的选择,有信心,这些都是无关紧要了。
在Shostakovich Cello Concerto No. 1里,定音鼓的爆发力紧凑,量感适中富弹性,像个身手敏捷的运动员,具备相当完美的原则——快、准、劲。大提琴的音色温暖,质感结实,高频延伸相当出色,空间感与空气感,皆在上佳水平。
听过Almarro A318B和Rogers LS 3/5a的LE配搭后,换上Exposure XXIII前级与Aragon 8008B,配搭Mirsch NG20喇叭。Vimak DT600声音温暖柔和,令人好奇的是胆味依然,音场通透,气派颇为开阔,尤其是在播放古典乐时,弦乐细腻处让颇具韵味,定音鼓的狙击,快而紧凑,量感与力道显得还有余力,以Shostakovich Cello Concerto No. 1的表现,定音鼓的爆发力宽广而富量感,低音能量的释放,相较Almarro和Rogers LS 3/5a LE,可说是另一番天地,但其本身特点依然,似个文将多过像个莽汉。
以Exposure XXIII及Aragon 8008B前后级组合播爵士乐时,Vimak可以说更为上手,乐器定位集中,发音点清晰,结像点的高度恰到好处,高频的延伸相当可观;相比胆机,其反应颇有电光石火之势,以脱胎换骨来形容,很是贴确。可见Vimak的设计师在声音的取向上,完全能抓住发烧友的感应神经,在器材的配搭上也相当容易,为用家除去不必要的烦恼。
在长时间的聆听过程中,发现DT600最为突出的特点是音乐背景宁静、细节丰富,人声秀丽淡雅,少了些妩媚与张扬,整体音场向后延伸,音像比例在Almarro和Rogers LS 3/5a LE的配搭下,显得集中而方正。而在Exposure XXIII前级与Aragon 8008B后级的配搭,加上Mirsch NG20喇叭的合作下,氛围仿佛在一个较大的录音间,音乐的展现更像是古典的工笔淡,细致而凝固,瞬态反应相当敏捷,低音紧凑而有力,但有别于强横下潜的凶悍,在此Vimak DT600巧妙地选择在不同范畴内发挥了自己的强项。若想要求DT600像个江湖侠士,展现出气霸山河、彪悍深沉的低音,则是较大的期待,因它更像在静态写生,而非如实地采风,取向有别,格局不同,切记!
假设你要求的是一种流动,抑或是绵绵不绝的生命力,那DT600将有一个期待落差,因为DT600特有的细腻手法,勾勒出来的相对静态的音乐气氛,也许更为接近发烧友的精雕细琢的参照点。流动与动感,更多的是体现在现场音乐会所展现出来的热力与感染力,这是也音乐爱好者在现场音乐演奏时的终极追求。
Price : RM 2850
HiFiLab
Number of posts : 2629
VIMAK DT-600 CD Player Empty bump
Post by HiFiLab on Wed Jul 12, 2017 8:07 pm
Up
HiFiLab
VIMAK DT-600 CD Player Empty BUMP
Post by HiFiLab on Sat Aug 12, 2017 11:11 am
UP
HiFiLab
Post by HiFiLab on Thu Sep 14, 2017 11:28 pm
UP
HiFiLab
Post by HiFiLab on Thu Dec 14, 2017 8:55 am
UP
HiFiLab
VIMAK DT-600 CD Player Empty Bump
Post by HiFiLab on Wed Nov 07, 2018 10:27 am
UP
HiFiLab
Post by HiFiLab on Fri Aug 09, 2019 9:36 pm
Up
HiFiLab
