NAD 302 Stereo Intergrated Amplifier (sold)
Description
The NAD 302 is an integrated amplifier. This 2-channel model is fitted with Phono MM/MC inputs. Furthermore, the stereo amplifier is integrated with preamp output and features LED indicators.
Because our engineers put sound quality first, the budget NAD 302 was voted European Amplifier of the Year 1993 - 94 and also a HiFi Choice ‘Best Buy’.
The 302 is modestly rated at 25 watts per channel into 8 ohms, but effortlessly handles peaks of 75 watts.
Tone Defeat allows you to switch out the tone control circuitry for a more direct signal path.
Important fine detailing like the low noise phono pre-amp, separate pre and power amplifier sections (for future upgrading) and heavy duty loudspeaker binding posts all add up to make a fine sounding, easy to use and hugely successful amplifier.
Power output: 25 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.03%
Damping factor: 60
Input sensitivity: 2.7mV (MM), 165mV (line)
Signal to noise ratio: 77dB (MM), 90dB (line)
Dimensions: 420 x 108 x 320mm
Weight: 6kg
- Number of posts : 2967
» NAD stereo intergrated amplifier(SOLD)
» AIWA XA-005 Stereo Intergrated Amplifier (sold)
» Onix OA 20/2 Stereo Intergrated Amplifier (sold)
» Arcam A65 Plus Stereo Intergrated Amplifier (sold)
» Rotel RA-01 Stereo Intergrated Amplifier (Sold)
