Power Amplifier Quad 606
Post by soumyajit.basu on Wed Dec 07, 2016 3:49 pm
Hi,
I am the new member of this forum. I have a question regarding Quad 606 MKI. I had purchase this power amp from India. First time when i connected the amp with power notice that a humming sound come from it. If it's a real problem please let me know how can i resolve this. Further, My question if I upgrade it MK II it will performance better compared to earlier version.
soumyajit.basu
Number of posts : 4
Registration date : 2016-12-07
Re: Power Amplifier Quad 606
Post by STC on Thu Dec 08, 2016 8:58 am
Determine whether the hum is mechanical or due to ground loop. If you don't hear the hum from the speakers and if the hum is beyond the noise floor of the room then I wouldn't worry to much about it.
Another cause of the hum is due to your electricity supply. Check the voltage. I do not have the actual reasoning but I noticed that I get the hum when the voltage was very high.
If it is ground loop then isolate the offending equipment. You could try to google on groundloop troubleshooting.
avatar
STC
Number of posts : 393
Registration date : 2010-08-15
Source(s): Ambiophonics setup.
Speakers: Electrostatics
http://goo.gl/CF1C6B
Post by soumyajit.basu on Thu Dec 08, 2016 12:51 pm
Thanx for your co-operation. The humming sound comes from inside the system. I think from the capacitor. It's come only from the amp. I didn't get any sound distortion from the speaker. I have checked it to my friends house too, same problem occurred.
soumyajit.basu
Number of posts : 4
Post by STC on Thu Dec 08, 2016 2:42 pm
Looks like mechanical hum. How loud was it?  There are a number of people facing similar problem with the Quads. Some say, the older Quad requires ground cable to be connect to your preamp. Some say, there is D.C. In the power supply. Sometimes, large capacitors will hum. Do you see any silicon or damping material on the capacitor? Check whether they are intact.
avatar
STC
Post by soumyajit.basu on Thu Dec 08, 2016 4:56 pm
I think large capacitor will hum. I didn't see any silicon or dumping material on the capacitor.
The sound is very low.
soumyajit.basu
Number of posts : 4
Post by yf9234 on Tue Jan 17, 2017 3:22 pm
soumyajit.basu wrote:I think large capacitor will hum. I didn't see any silicon or dumping material on the capacitor.
I have a 606 but there is non of the humming from the unit or from speakers
yf9234
Number of posts : 23
Registration date : 2010-02-16
Post by soumyajit.basu on Tue Jan 17, 2017 3:33 pm
STC wrote:Looks like mechanical hum. How loud was it?  There are a number of people facing similar problem with the Quads. Some say, the older Quad requires ground cable to be connect to your preamp. Some say, there is D.C. In the power supply. Sometimes, large capacitors will hum. Do you see any silicon or damping material on the capacitor? Check whether they are intact.
I contact with the mechanics regarding this humming sound, he told me that due to powers supply has been damage. Need to change power supply system.
soumyajit.basu
Number of posts : 4
