Brass Copper Spike Isolation Cone Feet with Base
Post by ActsessoryShoppe on Thu Dec 29, 2016 6:39 pm
Spike isolation cone feet suspends acoustic feedback from your speakers/subwoofer/amp/cd player etc equipment.
– to separate your players, amplifier or other audio components from vibration.
– The tones will be more focused and tighter, improved clarity, stereo imaging, and bass response
– Brass Copper material promises high specific gravity (density)
M5 sized screw
Base/floor disc included to protect the floor / surface from sharp tip.
* Set up the spikes under the equipment with top plate, OR screw into the speaker/device.
* No drill is needed.
* Screw to adjust the spikes make sure better contacted.
The sound kit comes with Spike Cone + Gold Base + 3M double sided tape
Weights 70g each spike with base pad
Base diameter: 25mm
RM13/set ( 1 spike & 1 floor disc )
Spike isolation cone feet suspends acoustic feedback from your speakers, subwoofer, AV rack or speaker stand.
– To separate your speakers / woofers or other audio components from vibration.
– The tones will be more focused and tighter, improved clarity, stereo imaging, and bass response.
– Solid weight copper promises high specific gravity
* Floor disc with M8 screw hole, can become top cover to be stacked on as well.
The sound tuning kit comes with Spike, screw plates, floor disc and top gold ring
Weights at 120g each spike with base pad
Base diameter: 35mm
RM20/set ( 1 spike & 1 floor disc )
011-31442297 @ Subang Jaya ss14
For more items : Actsessory Shoppe
Last edited by ActsessoryShoppe on Fri Mar 24, 2017 2:13 pm; edited 2 times in total
ActsessoryShoppe
Club Member
Club Member
Number of posts : 44
Registration date : 2016-12-27
Re: Brass Copper Spike Isolation Cone Feet with Base
Post by ActsessoryShoppe on Tue Jan 10, 2017 12:26 pm
ActsessoryShoppe
Club Member
Club Member
Post by ActsessoryShoppe on Sat Jan 14, 2017 11:27 am
weekend bump...
ActsessoryShoppe
Club Member
Club Member
Post by ActsessoryShoppe on Wed Jan 18, 2017 3:16 pm
Bump...!
ActsessoryShoppe
Club Member
Club Member
Post by ActsessoryShoppe on Mon Feb 06, 2017 12:19 pm
Bump...!
ActsessoryShoppe
Club Member
Club Member
Post by ActsessoryShoppe on Tue Feb 14, 2017 4:00 pm
Bump...!
ActsessoryShoppe
Club Member
Club Member
Post by ActsessoryShoppe on Thu Feb 23, 2017 3:35 pm
Bump...!
ActsessoryShoppe
Club Member
Club Member
Post by ActsessoryShoppe on Fri Mar 24, 2017 2:16 pm
Welcome...!
ActsessoryShoppe
Club Member
Club Member
Post by ActsessoryShoppe on Wed Apr 05, 2017 1:48 pm
location @Subang ss14
ActsessoryShoppe
Club Member
Club Member
