NHT Classic Two Stand Mount Speakers
Post by superfi on Sun Jan 15, 2017 11:12 pm
NHT's Classic Two may look like a bookshelf speaker, but it produces the kind of high-end sound with a grand sound stage that almost have you listening to a speaker several times its size.  Like all Classic Series speakers, the Classic Two features an acoustic suspension (sealed) enclosure design. This means it uses air — nature's most perfect spring force — to control the woofer motion, allowing for clean midrange and low distortion. It provides plenty of strength to let the 6-1/2" polypropylene woofer rock out without adding any unwanted resonance to your music or  movie soundtracks. The sophisticated 1" aluminium dome tweeter is set in a tiny bezel that allows the tweeter and woofer to be placed very close together. The result is exceptionally even on- and off-axis response point source response.
(Actual Picture - Top is covered by a layer of protective plastic hence the uneven edges - Condition 9/10))
This speaker features a beautiful, curvaceous cabinet made of very high quality dense, rigid MDF. It's covered in eight layers of high-gloss paint and two layers of clear coat that are hand-polished between each layer for a lasting black piano finish.
Specifications:
Frequency response:  51-20,000 Hz (+/- 3dB)
Sensitivity: 86 dB
6-ohm impedance
Power:  up to 125 watts
1” Aluminium dome tweeter
6 ½ “ Polypropylene mid-bass
5 way binding posts
Acoustic Suspension (sealed) enclosure
High Gloss (Piano Black) finish
7 “ W x 12” H x 9 ½ “ Depth
Weight: 12.7 lbs
Asking for RM1850 for the pair of beauties
Call 011-39300083 (Greg) or 012-2955266 (George) to deal
avatar
superfi
Number of posts : 265
Re: NHT Classic Two Stand Mount Speakers
Post by superfi on Wed May 24, 2017 11:54 am
avatar
superfi
Post by superfi on Tue May 30, 2017 3:59 pm
bump!
avatar
superfi
