Parasound HCA-2205A 5 Channel High Current Power Amplifier/ THX Ultra (Used)
Post by KhimAudio on Fri Feb 24, 2017 1:49 pm
Fetures:
-  Designed by John Curl
-  THX certified by Lucasfilm Ltd.
-  Independent power supply for each channel
-  Massive encapsulated 2 KVA toroid power transformer
-  30,000 uF power supply capacitance for each channel
-  Cascode Class A input stages with matched J-FET pairs
-  8 complementary pairs of 15 ampere 60 Mhz output transistors per channel
-  High-bias Class A/AB operation
-  Glass epoxy circuit boards, double-sided for precision
Specs:
-  Continuous power output, each channel:
   220 watts RMS x 5, 20Hz - 20kHz, 8 ohms, all channel driven
   300 watts RMS x 5, 20Hz - 20kHz, 4 ohms, all channel driven
-  Current capacity:
   60 amperes peak per channel
-  Net weight:
   85 lbs
Condition:  8/10
Price:  RM 4,900 or nearest offer
Contact:  Khim 016-3662081
KhimAudio
Number of posts : 1078
Re: Parasound HCA-2205A 5 Channel High Current Power Amplifier/ THX Ultra (Used)
Post by KhimAudio on Wed May 17, 2017 8:34 am
Up...
KhimAudio
