Luxman L-540 Integrated amplifier
Made: Japan (100V)
Condition: 8/10
Price:4000 3500
Contact: +60168828766 (nick)
Spec:
Effective output (8 ohms, both channel
simultaneous operation) 100W+100W
Class-A operation area:
15W+15W
THD 0.015% or less (8 ohms, an Output
power,
20Hz - 20kHz)
Cross modulation distortion 0.015% or less (8 ohms, 60Hz:7kHz=4:1,
Direct)
Input sensitivity/impedance Phono man month: 2.5mV/50kohm
Phono
MC: 100 microvolts/100 ohms
compact disk, Tuner, Line1, 2, Tape1, 2,
Processor:150mV/50kohm
Balance/Line: 150mV/50kohm
SN ratio (an IHF-A correction, input
short-circuit) Phono man month: 86dB or more
Phono MC:
74dB or more
compact disk, Tuner, Line, Tape: 108dB or more
Frequency characteristic Phono man month/MC:Less than
[20Hz-20kHz±0.3dB]
compact disk, Tuner, Line, Tape: 100kHz
[ 10Hz - ]-less
than 1dB
Tone Compensation The maximum variation: ±4.5dB
Power source AC100V, 50Hz/60Hz
Power consumption 300W (based on a convention of Electrical
Appliance and Material Control Law)
AC outlet Switched: Two lines, a maximum of 200W
Unswitched: One line, a maximum of 300W
Dimensions Width 438x height 176x depth of 467mm
Weight 24kg
http://audio-database.com/LUXMANALPINE-LUXMAN/amp/l-540-e.html
http://www.thevintageknob.org/luxman-L-540.html
Made: Japan (100V)
Condition: 8/10
Price:
Spec:
15W+15W
power,
20Hz - 20kHz)
Direct)
Phono
Phono MC:
74dB or more
[20Hz-20kHz±0.3dB]
[ 10Hz - ]-less
than 1dB
Weight 24kg
BetterHiFi- Frequent Contributor
- Number of posts : 134
Registration date : 2011-04-26
Re: Luxman L-540 Integrated amplifier
price reduced to 3500
price reduce to RM3000
» Luxman L-530 integrated amplifier
» Luxman L-550 integrated amplifier
» Luxman L 81 Integrated amplifier (used)
» Luxman L2 integrated amplifier
» Luxman L1 Integrated amplifier
