Tannoy GRF90
Tannoy GRF90
Post by Audioline on Fri Mar 17, 2017 10:29 pm
- Von Schweikert Audio
- PureAudio
- KR Audio
- TriangleART Turntable
- Endeavoraudio Audio
- Graham Audio
- Ensemble Audio
- Accuphase
- Cary Audio
- Rogers High Fidelity
- Sutherland (Phono Preamplifer)
- Audiodesk Vinyl Cleaner
- Artesania Audio (Rack)
- Zontek (Turntable / Tonearm / Phono Preamplifier)
- Mutech (Cartridge)
- Audio-Technica (Cartridge)
- The Wand (Tonearm)
- Glanz (Tonearm)
- Abis (Tonearm)
- ViV Laboratory Rigid Float Tonearm
Tannoy GRF90
Recommended Retail: SGD$29,000.00
The Gold Reference GRF 90 is a limited edition speaker marking TANNOY’s 90th Anniversary. Utilising a 300 mm (12") Gold Reference Dual Concentric™ driver housed in a beautifully designed, oiled walnut cabinet, provides the opportunity for music lovers to own an exclusive and high performance loudspeaker from the world-famous TANNOY Brand. GRF 90 uses the initials of the company’s founder, Guy R Fountain, who started the company in London in 1926.
The GRF 90’s 12" Dual Concentric with its signature PepperPot WaveGuide™, Alnico motor system and HF compression driver delivers a superbly dynamic overall presentation with fast, accurate bass and a fluid and open midrange. With 90 years of experience, TANNOY’s GRF 90 driver boasts an incredible 560 watt peak power while offering over 95 dB efficiency.
The crossover design utilises extremely high quality components in a minimalist design ensuring the shortest possible signal path to the driver and providing flawless musical reproduction. Featuring TANNOY-specification ICW ClarityCap™ MR capacitors, low loss laminated core inductors and thick-film resistors, the entire crossover is Deep Cryogenically Treated as a whole unit. The process has allowed the GRF 90 to achieve unparalleled gains in resolution and deliver an even more natural and cohesive sound.
Minimising cabinet resonance, the bespoke birch plywood cabinetry is extensively braced internally and the twin rear port is engineered to reduce low frequency turbulence. Meticulous hand finishing and time-honoured traditional craftsmanship are evident in the timeless beauty of the oiled walnut veneers and cabinet detail. Gold anodised machined metal trims, intricately detailed with TANNOY’s nostalgic lightning strike logo complement the overall stunning appearance of the loudspeaker.
Recommended amplifier power 20 -280 Watts
Continuous power handling 140 Watts RMS
Peak power handling 560 watt
Sensitivity 95dB (2.83 Volts @1 metre)
Nominal impedance 8 Ohms
Minimum Impedance 5 ohm
Frequency Response 24 Hz - 27 kHz (-6 dB)
Dispersion 90 degrees conical
1 Orchid Club Road,
Social Clubhouse Unit #02-33B,
Orchid Country Club
Singapore 769162
Feeder bus every 15 mins from yishun mrt at taxi stand area
Whatsapp / Line +65 98353600
Sunday & Monday       1200 HRS to 1700 HRS
Tuesday to Saturday   1200 HRS to 1800 HRS
Number of posts : 308
Registration date : 2010-01-23
