Fostex FT17H for Tannoy 611
4 posters
Fostex FT17H for Tannoy 611 Empty Fostex FT17H for Tannoy 611
Post by Syed Wed Mar 22, 2017 12:20 pm
Hi,
Recently, I have bought a pair of Fostex FT17H tweeters to compensate my Tannoy 611's which is a bit dull in high freq. I intend to use L-pad attenuators for the tweeters. Please, do anyone know where to get them locally? It's a frustrating to buy them online as Part express does not ship them to Malaysia.
Thank you.
Syed
Syed
Number of posts : 15
Registration date : 2011-04-19
Fostex FT17H for Tannoy 611 Empty Re: Fostex FT17H for Tannoy 611
Post by mierock Fri Mar 24, 2017 11:09 pm
bro,
there are some services for bulk shipping to Malaysia and use a local address in us. it will take some time though coz have to wait till the box full. a friend of mine use this kind of service and i usually tompang sekaki.
mierock
Number of posts : 172
Post by Syed Sat Mar 25, 2017 8:18 pm
Thanks for the response bro, how long will it take?
Syed
Post by mierock Sun Mar 26, 2017 7:21 am
a month or two. sometimes even less than that. i can ask my fren more info later, whenever he comes to my opis for breakfast.
mierock
Post by vt4c Sun Mar 26, 2017 11:49 am
Hare are some DIY speaker suppliers that you might want to try -
https://www.madisoundspeakerstore.com/l-pads-attenuators/
http://www.simplyspeakers.com/speaker-crossover-l-pad-a-542.html
http://www.speakercity.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=LPADS
http://solen.ca/product-category/resistors/variable-l-pads/
http://www.speakerbits.com/index.php?page=shop.browse&option=com_virtuemart
https://www.speakerworks.com/resistor_L_pad_8_ohm_15W_p/resl8ohm15w.htm
http://en.toutlehautparleur.com/ciare-yat-015.html
Of-course, eBay is worth searching for what you want as well....
vt4c
vt4c
Number of posts : 149
Post by hk5007 Sun Mar 26, 2017 9:31 pm
I have a pair of Tannoy 609. The 609 is comparatively dull even when new but you can listen for long hours without fatique. Partner with bright or transparent amp. Another reason why it is dull is because i think the ferror-fluid has dried up abit. I overcome the problem by changing the attenuator (resistor) to the tweeter. A 0.5ohm decrease in the resistor value should be sufficient. The 611 I believe is quite similar to the 609.
hk5007
Number of posts : 11
Registration date : 2009-06-05
Post by Syed Mon Mar 27, 2017 1:00 am
Thank you very much indeed vt4c, I hope could make direct order from one of them. And also thanks to you too hk5007, that sure is a good suggestion. However, I have already bought the fostex, looks like I have to proceed with project. Anyway if I can't get my hands on the L-pad, maybe need to switch to plan B, changing to lower resistors.
And thanks to mierock for your suggestion. I find this thread has given me some hope now. Let's see how it turns up. Thanks again guys.
Syed
