DEVIALET D220 Pro Integrated Amplifier (SOLD)
Stereo · 2x220Watts 6Ω
The best Stereo, the first step towards Dual-Mono.
The Expert 220 Pro is designed to meet the demanding needs of audiophiles with full connectivity and the world's most advanced phono stage.
It includes all Devialet exclusive technologies as well as major innovations developed for the new Expert Pro range.
Able to be linked to a second device to create an Expert 440 Pro, the Expert 220 Pro is the best solution to develop towards the extreme performance of the Dual-Mono configuration.
THD+N : 0,0005% (220W / 6Ω)
THD : 0,00025% (10W / 6Ω)
Signal-to-Noise ratio: 130dB
Advanced Phono stage
New ADH Intelligence
TECHNICAL SHEET EXPERT 220 ProTHD : 0,00025% (10W / 6Ω)
GENERAL SPECIFICATIONS
- Finish : Chassis carved out of a single aluminium block
- Colour : Dark chrome finish
- Dimensions : Length: 383mm | Width: 383mm | Height: 40mm
- Weight : 5.9Kg
- Installation : Horizontal or vertical installation with automatic tilt detection
- Synchronisation : Up to 8 units
PERFORMANCES
- Power : 2x220WRMS 6Ω
- Signal-to-Noise ratio : 130dB
- THD - 130W/6Ω : 0,0005% / -106dB
- THD - 10W/6Ω : 0,00025% / -112dB
- Output impedance : 0,001Ω
- Damping factor : 8000
- Bandwidth :
- DC-30kHz (-0.1dB)
- DC-95kHz (-3dB)
INPUTS / OUTPUTS
- Wi-Fi :
- 2.4GHz 802.11 b/g/n Wi-Fi input for the Devialet AIR universal streamer
- Supported formats: 16-bit/44.1 kHz PCM to 24-bit/192 kHz PCM
PHONO STAGE
- Type of supported cartridges: MM/MC
- MM sensitivity from 1mVRMS to 15mVRMS
- MC sensitivity from 100 μVRMS to 5000 μVRMS
- 256 combinations for the resistive/capacitive loading of the cartridge
- Stereo/mono/left/right mixing
- 13 equalisation curves available
- Specific menu for dynamic adjustment of all these settings
PREAMPLIFIER & MAIN DAC
- Patented Magic Wire Digital / Analogue Converter, D/A T.I. PCM1792
- Unique high-precision MasterClock with very low jitter: 2ps rms
- Conversion of all inputs into 24-bit/192 kHz
- Built-in DSD / PCM conversion
- SAM profile via configurator allowing the precise adaptation of the sound signal to the specifications of your speakers
- Available active filtering on all analogue outputs via configurator
- Volume control in increments of 0.5 dB
- Volume adjustment range: -97.5 dB to +30.0 dB
- Bypass/pass-thru mode available input by input
- Balance adjustment
- Tone control: bass +/-18 dB, treble +/-18 dB with variable frequency cut-off via configurator
OMNIDIRECTIONAL RADIO REMOTE CONTROL
- Chassis carved out of a single aluminium block
- Dark chrome finish
- Hand polishing, unique piece
- Dimensions: 114 mm x 114 mm x 34 mm (l, w, h)
- Weight: 343g (without batteries)
- Requires 3 AAA batteries (1.5V LR03), provided – service life of a set of batteries: 5 years
- No pairing required
- Ultra responsive, latency < 3ms
ELECTRICAL POWER SUPPLY
- Universal 90-240Vac – 50/60Hz
- Power cable provided adapted to the country
- Patented single stage switching mode topology
- High power level: 600W continuous, 4000W peak
- High output with power factor correction (PFC)
- High resiliency to hazards potentially encountered on distribution networks : brownouts, quick transients, overloads
- PLC Compatible
CONTENT OF THE BOX
- 1 Devialet Expert 220 Pro
- 1 Power cable
- 1 User Manual
- 1 Warranty booklet (5 years)
- 1 Microfibre cloth
- 1 Pair of gloves
- 1 SD card
- 1 Remote Expert (3 AAA batteries LR03 1,5V provided)
PRICE : SOLD
Please Contact us at 016-725 5372 ( Wendy ) or 012-6143049 ( Ms.Wee ) for further detail or to arrange for a demo in our showroom situated at Taman Melaka Raya , Melaka.
Mode of payment :
- COD Anywhere in Melaka town area
- PBB / MBB of purchase outside Melaka.
WTL_Trading- Dealer\Reseller\Trader\Service Provider
- Number of posts : 435
Registration date : 2016-06-29
» Devialet D-120 Integrated Amplifier (Used)(SOLD)
» Devialet D-120 Integrated Amplifier (Used) (SOLD)
» Devialet D-250 Integrated Amplifier (SOLD)
» Devialet Expert 250 Pro Amplifier
