Proceed AMP 3 - (150 to 250 WPC) 3 Channel Power Amplifier by Madrigal Audio (Mark Levinson)-Sold
4 posters
Proceed AMP 3 - Outstanding 3 Ch Amp (150 to 250 WPC) 3 Channel Power Amplifier by Madrigal Audio (Mark Levinson) Used & In Excellent Condition
SPECIAL DESIGN FEATURES OF THE PROCEED AMP 3 POWER AMPLFIER MULTIPLE MONAURAL DESIGN Consistent with the finest amplifiers, Proceed AMP is a true “multiple monaural” design. Each audio channel has its own, dedicated power supply—including a separate 300VA toroidal transformer for each channel.
This approach reduces crosstalk between audio channels for superior imaging and reproduction of acoustic space. The demands placed on one channel have virtually no effect on the performance of the other channel(s).
Proceed AMP 3 is certified for use in Home THX audio systems. Madrigal engineers have created powerful, versatile and extraordinarily musical power amplifiers, using the technology and design methodology for which they have become so well known.
Equally suited to the rigors of film soundtracks and the finesse of high end music reproduction, the Proceed amplifier serves both needs quite well. In today’s growing market for multi-purpose systems, they represent an extraordinary value." - taken from the Proceed AMP 3 Owner's Manual Proceed was a division of one of the best companies in audio, Madrigal Laboratories, which also produced Mark Levinson products costing up to $60,000.
Proceed specialized in home theater components; however, their amplifiers were so highly regarded that they were often used in high end, two channel audio systems. Proceed components were considered to be one of the most cost effective lines of high end equipment ever produced, as one would have to spend about 40% to 50% more to find a (slightly) better performing component.
Their amplifiers share similar design features, circuitry and components with the Mark Levinson products that often cost over $10,000, so they can easily drive any speaker and make them sound their best. Each channel contains a dedicated, low impedance power supply, so this 3-channel amplifier behaves as if it were three completely independent, high end mono amplifiers contained in one chassis.
In addition, this amp features dual-differential design to allow for true balanced operation, and accepts both RCA (single-ended) and XLR (Balanced) inputs. These features are very rare in a multi-channel amplifier, as most share a single power supply across all channels, and are not fully balanced.
SPECIFICATIONS Rated power output: 150 w/ch rms @ 8W, all channels driven, 20 Hz–20 kHz with no more than 0.1% THD 250 w/ch into 4W
Frequency response: within 0.1 dB from 20 Hz to 20 kHz Signal to Noise ratio: main outputs - better than –80 dB (ref. 1 w)
Input impedance: 30 kohms (balanced) 100 kohms (single-ended) Voltage gain: 23 dB (balanced) 29 dB (single-ended) Input sensitivity: 2.4 V for full rated output (balanced) 1.2 V for full rated output (single-ended.
Please check online reviews to view many 5 star range reviews given for this Proceed model.
http://www.audioreview.com/cat/amplification/amplifiers/proceed/amp-3/prd_116097_1583crx.aspx
Made in USA
THX Certified
- Proceed Amp3 is true multiple monaural design.
- Each audio channel has its own dedicated power supply.
- Each channel of the proceed amp 3 has both balanced XLR and single ended RCA inputs, with a small switch between the two connectors to select between them.
- Using these switches, select the appropriate input for each channel, given your interconnecting cables and pre amplifier's capabilities.
Selling due to low use and extra item (clearing space).
Condition: 8/10 due to no original box
Price: RM Sold (nego) original price was around RM12000
Just some minor scratches on the cover due to age but not obvious and this does not affect the sound performance and quality. You can see the attached photos.
Maintained in smoke free and pet free environment.
Amp is in Penang but can arrange delivery to other locations.
Contact: Anand (012-5885270)
Please sms or whatsapp for more photos and other info.
Thank you hifi4sale
Last edited by anandfm on Wed Jan 25, 2023 9:26 pm; edited 4 times in total (Reason for editing : Sold status)
anandfm- Frequent Contributor
- Number of posts : 978
Jeandaniel likes this post
Re: Proceed AMP 3 - (150 to 250 WPC) 3 Channel Power Amplifier by Madrigal Audio (Mark Levinson)-Sold
Bump with negotiable price.
john101- Club Member
- Number of posts : 27
Registration date : 2016-01-17
proceed amp
its avabile plz tell me price
radha- New Member
- Number of posts : 4
Registration date : 2020-09-15
Jeandaniel- New Member
- Number of posts : 18
Registration date : 2011-11-06
» Proceed Amp3 THX Power Amplifier by Madrigal / Mark Levinson (SOLD)
» Proceed HPA2 Dual Monaural Power Amplifier (Made by Madrigal/Mark Levinson)
» Used 3 Channels Power Amplifier from Madrigal (Mark Levinson) 500 Watts
» SOLD - USED Mark Levinson No.333 - 2 Channel Power Amp
