Harmonix (Sold)
Harmonix (Sold)
Made In Japan
Harmonix tuning feet are the first step towards perfect sound. Placed under CD players, turntables, preamps, power amps, speakers, and other equipment, these remarkable devices eliminate electronic and mechanical distortion to bring out a depth of sound you didn't even know was there. After positioning the tuning feet, turn up the volume and hear the difference: clearly defined instruments emerge with much cleaner edges; the sound range becomes more balanced, with richness and sensitivity in the mid range. Vocals snap with more accuracy and immediacy. There is a much quicker response, less decay, and no distortion. Harmonix tuning feet also reduce noise, jitter and rippling in video equipment, resulting not just in better sound, but also in better color contrast and vividness of image.
Tuning Feet
The first step in uncovering sound you didn't even know was there!
Sound Improvements from Tuning feet
1) Weaker sounds that went unnoticed before stand out.
2) The width of sound range delivered increases, for more volume and articulation.
3) Dynamic range and sound resolution increase, with no distortion at high volume.
4) Sonic uplift becomes crisper, and each sound more delineated.
5) Response becomes faster, with a quicker snap.
6) Heavy bass sound range expands for more presence.
Ideal For:
•Speakers of any size or type
•Preamps, power amps, pre-main amps, tube amps, solid state amps etc.
•CD players, analog players
•High end D/A converters
•Laser disc players, TV, projectors, DVD players etc.
“BeauTone” The succession of Harmonix flagship feet Model TU-1000. Indispensable feet to enhance the potentiality of components such as power amp, control amp, CD/DVD players/transports and other electronics. Improvement is just astonishing! Adjustable high by about 5mm allow perfect fit with the components.
•Materials: Selected wood with metal band
•Colors: Gold or black color band
•Size: 50mm diameter x 33mm high. Set of 4 pcs
•Weight allowance: several hundreds kilograms
(note: Place the unit over the center of the feet.)
- Number of posts : 2967
