Jadis JPL & JA30 Pre and Mono Block Amplifier
Post by vintageguys on Wed Apr 26, 2017 3:32 pm
Selling 1 set Jadis Pre amplifier  :
Description: Line-level preamplifier, with 4 general pairs of inputs, 1 CD pair of inputs, and 1 tape loop. Voltage gain: 35dB at 1kHz, for line-level inputs.
Dimensions: 17" (430mm) W by 7" (170mm) H by 11.8" (300mm) D. Weight: 29 lbs (13.2kg).
Monoblock Power Amp JA30 :
The JA-30 tube monoblocks has always been a very special pair of amps for us. Rated at 30W Class A, they are simply impossible to break away from once you have them powered up and playing. They have an amazing amount of bass, a very richly textured mid-range and smooth highs that will bring about a magical experience when you listen to them. Vocals were particularly holographic with a 3D like imaging. The amps are self-biasing (but must use a match pair) so it is almost like plug in and play. Very smooth and easy. This is the MK I and the difference between this and the MK II is that the MK II can run on KT-150 tubes for a slight increase in power output.
Asking : RM23,000.00
Please call / whatsapp +60 16 800 8896 Mr Tan for more info.
GOOD LUCK!
https://1.bp.blogspot.com/-MGPDUgZduHM/WQBKZ9h3iEI/AAAAAAAAC1M/6ec1c0ao6ZUtlIZNcdy3G2naqdECZBuuQCLcB/s400/IMG-20170424-WA0014.jpg
https://2.bp.blogspot.com/-Ut3wVuCNPLY/WQBKddPabzI/AAAAAAAAC1Y/13uNBY2vc28N8mY2leulmgNIn55tvyZ2gCLcB/s400/IMG-20170424-WA0024.jpg
avatar
vintageguys
Number of posts : 356
Amplification: WESTERN ELECTRIC 91B MONO POWER AMP
Speakers: WESTERN ELECTRIC 753C / Altec A5C / MRII 594A
http://myvintage-world.blogspot.com
Re: Jadis JPL & JA30 Pre and Mono Block Amplifier
Post by vintageguys on Fri May 26, 2017 3:15 pm
avatar
vintageguys
Post by vintageguys on Fri Jun 09, 2017 3:06 pm
avatar
vintageguys
