Classe CAV-75 Multichannel Amplifier - 6 channel (bridge-able)
Item: Classe CAV-75 Multichannel Amplifier - 6 channel (bridge-able)
Condition: Item is in excellent working condition. Exterior condition is also very good. Comes with original manual.
Price: sold
[size=31]CAV-75 75W SIX CHANNEL AMPLIFIER[/size]
The CAV-75 offers complete flexibility for use in a wide range of home theatre applications. The six channels of the CAV-75 can be easily customized to meet the amplification needs of the most demanding home theatre systems. You may bridge them to change the configuration to 5, 4, or 3 channels, increasing the power delivered to 1, 2 or 3 speakers to satisfy your theatre demands.
Classé's devotion to the creation of audio and home theater products of impeccable quality is an approach that an audiophile magazine recently called "a combination of art and science (that) exemplifies the best that high-end audio has to offer." This remarkable achievement is reflected in our worldwide reputation for unsurpassed musical performance, reliability, consistency, and overall value. Classé'sphilosophy is one of technological evolution, not revolution. Building on what we know works.
All Classé amplifiers share a common, unique design. Each model employs a massive, shielded toroidal transformer to power our sophisticated, high speed circuitry. In most high-end amplifiers, this power is sent to a small number of large reservoir capacitors for distribution. However, large capacitors are often slow in responding to the rapidly fluctuating energy demands of music and movie effects. The ingenious Classé solution uses a large number of small capacitors distributed throughout each amplifier which are located in close proximity to the circuits they supply. The result is a lightening-quick response, creating fabulous dynamics coupled with a more natural sound!
Microphonics, caused by component vibration and magnetic interference from the passage of electric current through them, has plagued audio designers since the beginning of recorded sound. Isolation is the key. At Classé, we begin with a unique front-end circuit topology that mechanically decouples vibration sensitive components from all sources of vibration. In addition, our transformers rest on a specially designed plate to draw magnetic fields away from the circuitry.
Bl-POLAR? MOSFET? J-FET? Most high-end amplifiers use only one type of transistor. At Classé, we use all three in a unique sequence that makes the most of their particular voltage and input impedance characteristics. In addition, we have designed small but highly efficient extruded aluminum heat sinks that disperse transistor
Frequency response: 20 Hz to 20KHz ±0.1 db
Sensitivity: 0.85 Volts in for rated output
Input Impedance: 75 KOhm
Output Impedance: 0.15 Ohm
Gain: 29 db
S/N Ratio: More than 135 db
THD + N: 0.004%
Maximum power and Channel configuration with 8 Ohms load:
Six (6) Channels - 75 Watts x 6
Five (5) Channels - 150 Watts x 1 (bridged) + 75 Watts x 4
Four (4) Channels - 150 Watts x 2 (bridged) + 75 Watts x 2
Three (3) Channels - 150 Watts x 3 (bridged)
Power consumption (idle): 75 W
Price: sold
Gain: 29 db
THD + N: 0.004%
» Used classe cav 180 / 5 channel
» Bryston 6B ST 3 Channel 250W per channel amplifier
» Halcro MC50 Multichannel Amplifier
» Classe amplifier. (SOLD)
» Perreaux SM5 Dual Channel Pre-Amplifier & 2370 Dual Channel Power-Amplifier (Used) - Reserve
