Sony TA-F333ESR Extreamely High Standard Stereo Integrated Ampifier with MM MC
Made In Japan
For sale a rare very high quality high end SONY TA F333ESR amplifier in excellent condition.
Amplifier in excellent working order,
no any issues.
This model has a Phono input with MM/MC feature and different loading (3 ohms, 40 ohms) for MC cartridges. Amplifier extremely well built, around 50 lbs.
Specs:
Model - Sony TA F333ESR Integrated amplifier
Effective output (20Hz ~ 20kHz) 140W + 140W (4Ω)
120W + 120W (6Ω)
105W + 105W (8Ω)
Output bandwidth 10Hz ~ 100kHz (50W output, harmonic distortion rate of 0.02%, 8Ω load)
Harmonic distortion rate 0.002% or less (at the time of 10W output, 8Ω load)
Intermodulation distortion - 0.004% or less (at the time of rated output, 8Ω load, 60Hz: 7kHz = 4: 1)
Through late - 125V / μsec
250V / μsec (Inside)
Damping factor - 100 (1kHz, 8Ω load)
Frequency characteristic Phono MM: RIAA curve ± 0.2dB
CD, Tuner, Tape, Adaptor, Direct: 2Hz ~ 200kHz +0 -3dB
SN ratio Phono MM: 87dB
Phono MC: 68dB
CD, Tuner, Tape, Adaptor, Direct: 105dB
Input sensitivity / impedance Phono MM: 2.5mV / 50kΩ
Phono MC (40Ω): 170μV / 1kΩ
Phono MC (3Ω): 170μV / 100Ω
CD, Tuner, Tape, Adaptor, Direct: 150mV / 50kΩ
Output level / impedance Rec out: 150mV / 1kΩ
Speaker: fit impedance 4Ω ~ 16Ω
Headremoved phone number for privacymW / 8Ω
Tone control Bass: +4 -3.5dB (100Hz, turnover frequency 200Hz)
+6 -5dB (100Hz, turnover frequency 400Hz)
Treble: +7 -8dB (10kHz, turnover frequency 3kHz)
+4 -5dB (10kHz, turnover frequency 5kHz)
Subsonic Filter 15Hz or less, 6dB / oct
Power consumption - 270W
External dimensions Width 470 × height 165 × depth 435mm
When the side wood removed: width 430mm
weight - 21.2kg
Price : RM 2350
- Number of posts : 2967
BUMP
UP
BUMP
UP
BUMP
UP
BUMP
UP
Up
» Sony TA-F444ESX Extremely High Standard Stereo Integrated Amplifier with MM and MC
» Sony TA-F333ESR Integrated Stereo Amplifier (Used)- SOLD
» Sony TA-F333ESR integrated amp (Used)
» Sony TA-F333ESR Integrated Amplifier (SOLD)
» TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier
