Naim England SuperUniti Stereo Amplifier
Post by HiFiLab on Sun May 28, 2017 10:57 am
Made In England
80 Watts Per Channel @ 8 ohm
Specifications:
Audio Inputs
– 1 x coaxial BNC – up to 24bits/192kHz
– 1 x coaxial RCA – up to 24bits/192kHz
– 3 x optical TOSlink – up to 24bits/96kHz
– 1 x front panel mini-TOSLINK – up to 24/96kHz
Analogue –  2 x RCA, 1 x front panel 3.5mm jack (combined optical), 1 x DIN
USB – 1 x front panel Type A socket
Input Sensitivity – 270mV at 47kΩ
Wi-Fi  – (802.11 g or n at 2.4GHz), F type (plus PAL adapter)
Antenna – 802.11 b/g at 2.4GHz
Spotify Connect, Tidal ,Bluetooth (SBC, AAC and aptX Classic, aptX Low Latency)
Audio Outputs:
Digital (S/PDIF) – 1 x BNC (75Ω)
Analogue – Speaker output, preamp output (RCA)
Power Output – 80W per channel into 8Ω, 120W per channel into 4Ω (0.1% THD both channel driven)
Frequency Response – 10Hz-20kHz, +0.1/-0.5dB
Signal-to-Noise Ratio – W85dB A-WTD ref 1W 8 Ω
Output Impedance – 22Ω
Load Impedance – 10kΩ min
Sub Output – 1 x RCA pair
Headphone Output – 1 x 3.5mm jack
Remote Control – Infra Red (RC5)
Audio Formats
WAV (up to 24bit/192kHz)
AIFF (up to 24bit/192kHz)
FLAC (up to 24bit/192kHz)
DSD (single rate DSF64 & DFF64 only)
ALAC (up to 24bit/96kHz)
WMA (up to 16bit/48kHz) must be WMA 9.2
Ogg Vorbis (up to 16bit/48kHz)
M4a (CBR and VBR up to 320kbit/s)
MP3 (CBR and VBR up to 320kbit/s)
Playlists – (M3U, PLS)
Internet Radio Provider – vTuner 5* full service
Internet Radio Formats: Windows Media-formatted content, MP3, ACC, Ogg Vorbis streams and MMS
Multiroom
Master: Will stream WAV, FLAC and AIFF (up to 24bit/48kHz), ALAC (up to 16bit/44.1kHz), AAC and MP3 (up to 16bit/48kHz) files only as MP3 320kbps quality.
DAB Tuning Range – Band III and L Band, F Type
FM Tuning Range – 87.5 – 108MHz, F Type
User Control
Handheld remote handset included and optional Naim app for iOS and Android.
Power Supply Voltage – 100V, 115V, 230V; 50 or 60Hz
Power Consumption – 400VA (max)
Dimensions (HxWxD) – 87 x 432 x 314 mm
Weight –12.8kg
Price : RM 13800
HiFiLab
Number of posts : 2035
BUMP
Post by HiFiLab on Sun Jul 30, 2017 9:51 am
Up
HiFiLab
