Sansui SP-200 Vintage Speaker with Upgraded Cabinet
Post by HiFiLab on Fri Jun 30, 2017 12:13 am
Creative Speaker Design Based on Repeated Hearing Tests as Well as on Laboratory Test
Speaker performance may be well measured by laboratory instrumentation. But "live" sound must be proved by human ears or hearing test. Thus, Sansui's speaker system is designed on the basis of a wide variety of data obtained from repeated actual test as well as from laboratory tests. These tests have been made not only in our modern laboratory  and test rooms made of different construction materials.
That's why Sansui's SP series system can reproduce lifelike stereo sound wherever it may be installed.
3-way 5-speaker system
The SP-200 is a full range 3-way 5-speaker system consisting of a 12-inch woofer, two 5-inch midrange speakers and two 2-inch horn type tweeters.
It can faithfully reproduce deep, rich lows, and clean, transparent highs, and all the tones in between.
Woofer - Designed to match the "pipe-ducted" bass reflex type enclosure. Its edge, paper cone, damper and other components are all designed to give the best linearity even at any big amplitudes, assuring good damping characteristic at low frequencies.
Midrange - It is  often said that the quality of midrange determines the value of a speaker system. Generally many speaker systems tend to neglect the midrange, giving too much care to hig and low frequency ranges. The Sp-200 is provided with two 5" rear-sealed hgih-performance midranges whose powerful magnetic circuit prevents any interference with the woofer. They can reproduce a live sound of strongly attacked percussion instruments as if they were played just before you.
Tweeters - the clear, clean, transparent highs are a measure of a performance of a speaker system. The SP-200 posesses two horn type speakers whose frequency response is more than 20,000 Hz  and whose transient response is excelent, too. You can enjoy romantic mood of strings as it is.
Faithful Reproduction of Bass Tones by Pipe-Ducted Bass Reflex
The Sansui's exclusice "pipe-ducted" bass reflex enclosure helps reproduce original bass tones faithfully. The bass sounds that are boomy or exaggerated in a limited bass range never deserve the name of Hi-Fi. In order to match the pipe-duct characteristics, the woofer is designed to lower "f₀" greatly by the cross edge, assuring the faithfull reproduction of the lowest
Interference-Free Positioning of Speaker
Although the installation of two or more speakers in one box often leads to the mutual interference between them, the SP series system solved such a problem through years of our researches on the positioning of the speakers.
Specifications SP-200
Low Frequency : 12" cone woofer
Mid Frequency :  two 5" cone type midrange
High Frequency :  two 2" horn type tweeters
Maximum Input:  40 watts
Input Impedance:  8 Ω
Frequency Response:  35 - 20,000 Hz
Note : Previous Owner Spend a lot effort to upgrade this Sansui Speaker cabinet for better sound and good looking .
welcome to test the sound,thanks
Price : RM 980
HiFiLab
Number of posts : 2011
