Jasmine TT D-200 Turntable, Customized Edition with 2 additional Tonearms (SOLD)
Selling a Customized Edition Jasmine TT D-200 in Red, comes with additional New Consonance T88S 12 inch tonearm and a ClearAudio Clarify 9 inch tonearm. Cartridges and clamps are not included. Do Whatsapp if interested!
PLEASE READ THE DESCRIPTION, BEFORE COMMENTING ANYTHING. PRICE WILL BE STATED HERE. PERSONALLY WHATSAPP IF INTERESTED IN BUYING OR YOU HAVE ANY QUESTIONS. BRIEF DESCRIPTION OF THE TURNTABLE WILL BE WRITTEN HERE.
Jasmine TT D-200 turntable:
For Specifications Click Here: http://www.jasmineaudio.net/TT-D200.html
Consonance T88S 12 inch Tonearm:
T88S has a unique combination of bearings. A high precision ball-bearing assembly is used for the horizontal plane of motion. Two single point bearings are incorporated for the vertical mode of motion. So T88S in the vertical direction with a flexible single-point bearing and in the horizontal direction more stable and solid, the adjustment becomes easy.
- Mounting Distance Arm Base: 294mm
- Tonearm Length: 12 inch
- Overhang: 12mm
- Offset: 17 degree
- Cartridge Weight: 4 -22g
- Mass (Without Counterweight): 115g
- Counterweight: 130g
ClearAudio Clarify 9 inch Tonearm:
The Clarify builds upon Clearaudio’s friction-free magnetic bearing technology found in their successful Verify and Verify CF tonearms. Like the Verify CF, it features a carbon fiber arm tube which reduces resonance for enhanced clarity and the Clarify’s precision machined aluminum headshell features adjustable azimuth. Additionally, fine adjustments for VTF and anti-skate are easily performed with precision controls, assuring the most accurate phono cartridge set-up. The Clarify is hardwired with Clearaudio’s Direct Wire tonearm cable, assuring signal integrity and making it ideal for all high quality phono cartridges including low output moving coils. The Clarify uses the Clearaudio/Linn standard mount, making it compatible with all Clearaudio turntables and an ideal replacement tonearm for other brand turntables.
- Tonearm Weight: 320g 410g including counterweight
- Zero Points: Inner- 66.0mm, Outer- 120.9mm
- Audio Lead: Clearaudio Direct Wire
- Overhang: 17.31mm
- Overall Tonearm length: 335mm
- Effective Tonearm length: 9 inches/ 239.3mm
- Pivot to Stylus: 222mm
- Anti-Skating factor at radius of 62.9mm and 126.9mm: 0.43
- Mounting Style: Linn/ Clearaudio
Condition: 9/10
Selling Price: RM 14,000
Whatsapp: +60164221082/+60124278800
(Click Images to View Full Picture)
- Overhang: 12mm
- Offset: 17 degree
- Overhang: 17.31mm
Condition: 9/10
cliffwong90- Frequent Contributor
- Number of posts : 328
» Jasmine TT D-200 Turntable with Consonance T1288 and Jasmine MC Turtle Catridge (SOLD)
» Elekit TU8200 Tube Amp with additional upgrades (sold)
» Harbeth M30.1 [Rosewood] + Customized Skylan Stands
» Rega QUEEN Limited Edition turntable (Sold)
» Rega RP40 Limited Anniversary Edition turntable SOLD
