Adcom GFA-535 Stereo High Current Power Amplifier
Post by HiFiLab on Wed Jul 12, 2017 10:46 pm
Power Amplifier
Description:
Two-channel,
solid-state amplifier.
Output power: 60W into 8 ohms (17.8dBW).
Input sensitivity: 970mV RMS.
Input impedance: 100k ohms.
Frequency response: 10Hz–20kHz, –0.25dB.
S/N ratio: 110dB. Power consumption: 300W.
Dimensions: 3" H by 17" W by 11.25" D.
Weight: 19.5 lbs.
Nelson Pass, famous for Threshold and Nakamichi Stasis amps, designed the GFA-5X5 series for Adcom and the 555 got a string of rave reviews.
Good as it was, anyone who worked with these amps will tell you the best of the bunch was the 535. Beautiful build quality, 4 big outputs per side, real heatsinks and a true dual mono design with twin transformers. It is a very musical amp with wonderful imaging and a more natural balance than its bigger siblings.
The Adcom GFA-535 is the little brother to the famed 545 and 555 amplifiers. It features true dual mono construction with each channel getting its own power transformer and power supply capacitors. With a simple design by the famed Nelson Pass, it features pretty much the same input/driver circuit as the big amplifiers and also has bi-polar output transistors. Rated at a conservative 60WPC, the original version has two sets of speaker output using twist connectors for bare wires. The small size makes it perfect for sitting on top or underneath a matching Adcom preamplifier.
Price : RM 1280
HiFiLab
Number of posts : 2155
