HDMI Cables: DHlabs, Supra, Audioquest, etc
Post by raymond88 on Fri Jul 14, 2017 4:50 pm
Item: DHlabs Swivel HDMI 2.0A - 2m
Condition: 8/10. Item in good working condition
Price: sold
The DH Labs Swivel HDMI cable is the leader in its class, and unsurpassed at this price point.   HDMI 2.0a Certified for 2160p, 4k, 2k Ultra HD, & 3D TV.   The unique machined swivel connector is ideal for today’s low-profile monitors, and provides ultra tight contact/fit for maximum quality signal transmission.  Available in 0.5 Meter, 1.0 Meter, 1.5 Meter, 2.0 Meter and 3.0 Meter lengths.  USA shipping only via USPS Priority Mail Small Flat Rate Box (if ordered separately).
***************************************8
Item: Supra HD5 Standard High Speed HDMI with Ethernet Cable - 2m
Condition: 8.5/10. Item in excellent condition. Few months old only.
Price: RM300
http://www.futureshop.co.uk/supra-hd5-met-sb-high-speed-hdmi-with-ethernet-cable-2m-p-8637.html#.WWiEp4SGPIU
SUPRA launched its first HDMI cable in 2004. 9 years of continuous product development has resulted in the Supra HD5 HDMI, which (according to Supra) is the best HDMI cable on the market, offering HDMI High Speed with Ethernet & 4K resolution. They guarantee that the cable can handle all HDMI signals up to 32m. SUPRA HD5 is tested and approved in compliance with the latest test provisions by HDMI´s Accredited Testing Center in the USA. A secure quality guarantee of there HDMI cables. The bandwidth in the HD5 (used in all of there HDMI/DVI cables) is 1100MHz, almost four times the spec of HDMI High Speed (340MHz). There are some interesting cables out there claiming to do the job but only a few are actually approved for it. SUPRA HDMI is a safe choice.
High resolution picture and sound
We often meet scepticism when we talk about HDMI cables. ”Does it really matter?” ”I mean, it’s only a data stream? Yes, it is a stream of digital bits. Yes, it does matter. Unfortunately there is an intermediate state before the signal is so corrupt it cannot be read and blanks out. Many claim that if the screen shows, the signal is good enough. There is circuitry in the receiver which tries to repair broken data stream by buffering and error correction, but this is based on best possible estimates and is not necessarily what was sent. You might experience sync problems (delays), distorted colorations, insufficient blackness, noise and unexplainable audible pops during which the hardware is working overtime trying to repair the fragile bitstream. Do your precious hardware the best possible favour you can by connecting it using SUPRA HDMI cables and both you and your equipment will fully enjoy the show.
SUPRA HDMI Features & benefits:
  • Transmits today’s challenging formats flawlessly
  • Future proof - Meets today’s HDMI standard and known requirements of tomorrow
  • Sturdy design - Withstand the normal installation abuse
  • 23AWG leads - For minimum losses
  • Triple screen technology - Provides for long distance clearance hence freedom of installation with maintained signal integrity
  • Made in Sweden, three step quality plan - Unsurpassed quality and reliability
Features:
  • Supra HD5 Standard High Speed HDMI with Ethernet Cable
  • Length: 12m
  • Signal Bandwidth: 340 MHz
  • TMDS Bandwidth: 10.2 Gbit/s
  • Colour Depth: 48 bit/px
  • 4K x 2K Resolution support: Enables video resolutions far beyond 1080p. 3840 x 2160 24Hz/25Hz/30Hz 4096 x 2160 24Hz
  • Deep Colour, x.v.Colour
  • Auto Lip Sync
  • Dolby TrueHD, DT-HD Master Audio
  • 3D over HDMI
  • Audio Return Channel
  • Ethernet Channel
Specifications:
  • Cable SUPRA HD5
  • Standard HDMI 2.0, High speed with ethernet
  • Connection Config: Single-Link
  • Connectors: HDMI-HDMI
  • Signal Direction: <->
  • Application Examples: DVD/Projector/TV
  • Max Resolution: 4K
  • Solder Tin: Almit SR-34 Super
  • Cable clamping: Molded
  • Cross section Area: 5xTMDS 0.26/23 (mm2/AWG)
  • Wire Material: Solid OFC
  • Insulation: PE Foam
  • Inner Screen, Coverage: Alu/PET Foil, 100%
  • Comm. Conductors: 5xAWG 26 PE
  • Outer Screen, Coverage: Alu/PET Foil & Braid, 100%
  • Jacket: Heat & Ageing Resistant PVC
  • Cable diameter: 9.5 (mm)
    Electrical Performance:
  • Resistance: 82 (Ohm/km)
  • Capacitance: 42 (pF/m)
  • Char. Impedance: 100 (Ohm)
  • Velocity Factor 0.8c
Item: AudioQuest Vodka HDMI Digital Video Cable - 2m
Condition: Item is in excellent condition
Price: RM550 RM390
Thank you.
Number of posts : 4204
Re: HDMI Cables: DHlabs, Supra, Audioquest, etc
Post by raymond88 on Mon Sep 18, 2017 12:36 pm
Post by raymond88 on Sat Oct 21, 2017 1:48 am
Post by raymond88 on Sat Dec 09, 2017 3:21 pm
Post by raymond88 on Mon Jan 15, 2018 6:05 pm
