KEF Carlton II 204 England Made Floorstanding Speaker
Post by HiFiLab on Sun Jul 16, 2017 11:29 pm
Made In England
KEF Carlton II is a high-quality floorstanding speaker intended for use in living room of average size
Superseding the famous Model 104aB ( •Apparently the Carlton II is a re-work of the Cadenza and 104aB. ), Those speaker offers remarkable accuracy of reproduction with extended bass response
Carlton II features
- Flat frequency response from 47Hz to 20 kHz
- Extended low-frequency response
- High Aoustic output -106dB spl on programme peaks
- Low colouration
- Computer designed crossover network
- Natural wood finish
Carlton II Benefit
with an amplifier output of as little as 15 watts per channel,
Carlton II will provide adequate volume levels for domestic use.
with more powerful amplifiers, higher volume levels can be easily achieved whilst maintaining tonal quality
A new method of bass loading maintains output cleanly down to 29Hz
whilst minimising the effects of sub-sonic signal produced by record warp and turntable rumble
Kef Carlton II's.
Amp friendly. Efficient & suitable with lower power than most KEF's, but pairing with HQ sources will reveal stunning realism.
Drivers are excellent, electronics 100% original. Well matched and balanced.
B-200 8" mid-woofer, T-33 8ohm tweeters, + passive radiator. Extended bass, clean and punchy. Same active driver set as the Reference 103.2.
I'd describe these as like the 104aB but more refined. Absolutely nothing new even comes close to the sound of these any point near the cost here.
28" x 11..5" x 12.5"
Type: 2 way, 3 driver loudspeaker system
Frequency Response: 47Hz to 20kHz
Power Handling: 100W
Recommended Amplifier: 15 to 100W
Impedance: 8ohm
Sensitivity: 86dB
Enclosure: 44 litre, bass reflex
Dimensions: 700 x 315 x 280mm
Weight: 12kg
Distortion: Measured at 1m on reference axis at mean spl of 90dB, anechoic conditions. Second harmonic: less than 1% from 60Hz to 20kHz. Third harmonic: less than 1% from 150Hz to 20kHz
Enclosure Type: Mechanical reflex, Tuning frequency 28Hz
Characteristic Sensitivity Level: 86dB spl at 1m on reference axis for pink noise input of 1W
Nominal Impedance: 8 ohms
Internal Volume: 44 litres
Directional Characteristics: Within 2dB of response on reference axis up to 20kHz for +/-5° vertically and up to 10kHz for +/-20° horizontally
Maximum Continuous Sinusoidal Input: 20V rms from 20Hz to 2.5kHz reducing to 8V rms from 4kHz to 20kHz
Maximum Output: 106dB spl on programme peaks under typical listening conditions
Frequency Response: 47Hz to 20kHz +/- 2.5dB at 2m on reference axis (-10dB at 29Hz and 30kHz)
Minimum Amplifier Requirements: 15W
Note : Same model with KEF 204 speaker
Price : RM 2250
HiFiLab
Number of posts : 2009
