TEAC UD-501 DSD 5.6MHz / PCM 384kHz capable Dual Monaural D/A Converter DAC (SOLD)
Post by AnelasXintus on Wed Jul 19, 2017 2:22 pm
Item was purchased NEW but was barely used. I could recall using it 8 times or less to play via USB from my music dedicated laptop to my amplifier. I never got around to purchasing more HD audio or upgrading my speakers so I'm letting this go.
Item is in GREAT CONDITION without any blemish or marks apart from a very light/dull line at the base likely caused by my vibration isolation stand when I accidentally moved the unit at some point. I could likely erase this with a pencil eraser.
Condition Rating according to hifi4sale.net is 8.5/10 which means:
- Mint condition
- Contains all accompanying accessories
- No original Box or packaging
Price: MYR 2299.00
Warranty: N/A
Chat with me on Carousell mobile App. to know more or PM me for more information.
https://my.carousell.com/japanknifearts/
Serious buyers are welcome to come audition the unit but I don't have DSD anymore, only FLAC.
The most you can get out of the audition is just to know that it works unless you bring your own Laptop, Media, and Headphones.
External Reviews:
http://av2day.com/2014/10/teac-ud-501-dsd-dac-the-game-changer/
https://www.audiostream.com/content/teac-ud-501-dual-monarual-pcmdsd-usb-digital-analog-converter
http://www.theabsolutesound.com/articles/teac-ud-501-digital-converter/?page=3
http://archimago.blogspot.sg/2013/05/initial-impressions-teac-ud-501-usb-dac.html
https://www.whathifi.com/forum/dacs/teac-ud-501-dsd-dac
SPECIFICATIONS
Digital audio inputs:-
COAXIAL: RCA ports x 2 (0.5 Vp-p/75 ohms)
PCM data sampling frequency: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz
bit rates: 16/24-bit
OPTICAL: Optical digital connectors x 2 (–24.0 to –14.5 dBm peak)
USB: Type B connector x 1 (USB 2.0 compliant)
PCM data sampling frequency: 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz
bit rates: 16/24/32-bit
DSD data sampling frequency: 2.8/5.6MHz
Analog audio outputs:-
XLR: XLR ports x 1 pair
Output impedance: 88 ohms
Maximum output level: 4.0Vrms (1/full-scale, into 10 kΩ)
Frequency range: 5Hz - 80kHz (-3dB)
S/N ratio: 115dB
Distortion: 0.0015% (1kHz)
RCA: RCA jacks x 1 pair
Output impedance: 22 ohms
Maximum output level: 2.0Vrms (1/full-scale, into 10 kΩ)
S/N ratio: 115dB
Headphones output :
Connector: Standard 6.3 mm stereo port
Maximum output: 100 mW + 100 mW (into 32 ohms)
Power supply: AC 230 VAC 50/60 Hz
Power consumption: Max 13W (Auto power save standby mode: 0.1W)
Overall Dimensions: 290 (W) x 81.2 (H) x 244 (D) mm, [11.4" (W) x 3.2" (H) x 9.6" (D)]
Net Weight 4.0kg (8 15/16 lb)
Operating Temperature +5˚C to +35˚C [+41˚F to +95˚F]
Operating Humidity 5% to 85% (no condensation)
Storage Temperature -20˚C to +55˚C [-4˚F to +131˚C]
Accessories AC Cable, AC Plug Adapter (3P), Stereo RCA Cable
Images:
the screws are not rusty, they are so polished you see my reflection.
AnelasXintus
Number of posts : 2
Registration date : 2014-08-26
