Copland CTA 520 Power Amplifier
Post by raymond88 on Wed Aug 09, 2017 2:13 am
Item: Copland CTA 520 Power Amplifier
Condition: 8.5/10. Item is in excellent working condition. No dents or scratches on the body.
Price: sold
Copland CTA 520 Power Amp per unit specification:
-  Rated power output: 125 watts x 2 channel at 8 ohms
                                250 watts x 1 channel in bridge mode
-  Power consumption: 600 W
-  Inputs: RCA x 2, RCA x 1 (Mono) and Balanced XLR (Mono)
-  Weight: 14kg
UHF magazine (no. 66) summed up its review of the 520: ‘The very best solid state amplifier Copland has produced, and by a long margin"
A two channel power amplifier in a slim line chasses. Combining the virtues of valve design with solid state circuit for high power stability and strong dynamics driving any speaker load with a clean undistorted signal.
Field effect transistors are used for both the input and driver stages. Like vacuum tubes they are voltage controlled and allow for circuitry design with a minimum of non-even harmonic distortion.
The CTA 520 remains faithful to the sound virtues of other COPLAND products. A firm grip on the lower octaves, an accelerating treble and most significantly a musicality, attributed to all COPLAND designs.
For systems demanding more than 125W per channel or requiring balanced operation, we recommend one CTA 520 per channel in bridge mode or as fully balanced mono amplifier using the XLR input terminal.
The CTA 520 standby switch can be controlled from the COPLAND CTA 305 pre-amplifier or the system remote control.
3495.00 USD
Rated power 125 W / channel at 8 ohms
250 W / bridge or balanced operation
Less than 0,05% at all levels
Frequence response
20-20 kHz - 0, 2dB
Input sensitivity 1,4V for rated power
Input impedance
50 K ohms (single ended inputs)
50 K ohms (balanced inputs)
S/N ratio More than 103 dB
Power consumption 600W
Nominal mains voltage 115V or 230V factory set for destination country only
Mains voltage range +/- 12%
Dimensions 430 (W) 86 (H) 390 (D) mm.
Weight 18 kg.
Number of posts : 3532
