A Bel Canto S300 Dual-Mono Stereo Audio Power Amplifier from USA
Post by meridian-506 on Sat Aug 19, 2017 2:46 pm
For your consideration, an excellent condition, Bel Canto S300 Dual-Mono Stereo Audio Power Amplifier, selling at RM3.5k / S$1.1k.
This Bel Canto S300 Dual-Mono Stereo Audio Power Amplifier has a Max Power Output of 300W into 4 ohms & 150W into 8 ohms.
It has High-Quality Balanced (XLR) and RCA Input Connectors.
Excellent for use as the Amplifier to Upgrade/Drive your Current/Intended Speakers.
Silver-Faceplate, this set was originally purchased from the Local Agents in Singapore (Sound Decisions), is still under Warranty till mid-Febuary 2018 and comes with the Original Manual & Box.
This Bel Canto S300 Dual-Mono Stereo Audio Power Amplifier is Made in the USA.
Pictures Link :
Excellent detail can be found at the following Website / Reviews / Manual :
http://www.6moons.com/audioreviews/eone/s300.html
http://www.enjoythemusic.com/magazine/viewpoint/0206/nearfield10.htm
http://hometheaterreview.com/bel-canto-eone-s300-power-amplifier-reviewed/
https://www.audioasylum.com/messages/amp/135359/review-bel-canto-design-e-one-s300-amplifier-ss
http://www.belcantodesign.com/pdfs/UG_M300_S300.pdf
Some Quotes :
" The e.One S300 Dual-Mono Audio Power Amplifiers that deliver up to 150 watts into 8 ohm loads and 300 watts into 4 ohm loads.
Each amplifier contains its own dedicated regulated power supply for all amplifier stages, including the output section.
This is achieved in a compact and elegant product through our adaptation of the latest analog switching amplifier and power supply technology from the ICEpower group.
Bel Canto’s new generation of e.One analog switching audio power amplifiers extend our leadership in this technology.These amplifiers incorporate performance enhancing technologies that bring musicality and performance to new levels. "
" This technology brings unprecedented performance gains in absolute musical performance.
The regulated power supply and fully balanced analog switching amplifier architecture liberates your loudspeakers to perform at their best.
The ultra-low noise operation insures that the most subtle of musical expressions comes through with palpable clarity.
The superb measured performance insures that harmonic and intermodulation distortion don’t interfere with the pristine beauty or raw power of the musical message.
The e.One series amplifiers from Bel Canto insure that you fully experience the musical intensity and beauty of your favorite artists."
" The audio amplifier is the engine of the audio system. It must provide the power to drive the loudspeaker motor.
The amplifier has huge power gain: from micro-watts of input power to 100’s of watts of output power the audio amplifier must do its job with ease and competence.
Key issues that must be addressed in a high performance audio amplifier are :
*  Power supply design defines the performance limit of the amplifier, fully regulated power supplies provide the standard for fidelity.
*  True balanced operation improves the signal fidelity under load.
*  Balanced input insures that the large output/input power ratio does not corrupt the input signal fidelity.
*  Low output stage impedance, especially at low frequencies, insures maximum control of the loudspeaker driver.
*  Comprehensive protection circuit that is outside the signal path is critical to protecting both the amplifier and loudspeaker.
*  A short, simple, signal path with a minimum of output devices leads to a better audio performance.
All of the Bel Canto e.One amplifiers are designed to optimize performance of all of these criteria.
The S300 provides ground breaking performance in a compact, dual mono chassis design able to supply 300 Watts of power.
Each S300 amplifier channel has its own fully regulated switching power supply, true balanced operation, 4 ohm drive capability and 111dB of dynamic range.
With the S300 in your system it will sound like you are connected directly to the music source, the loudspeaker and amplifier effectively disappear in the large and compelling sonic picture.
Fidelity and signal clarity is unmatched from the lowest audio frequencies through to the sweetest high frequencies.
The utter mid-range clarity especially allows the music to communicate as never before.
Discover what this remarkable amplifier technology can do for your audio system. "
Originally purchased from the Local Agents in Singapore, this Bel Canto S300 Dual-Mono Stereo Audio Power Amplifier is the 220/240V version and is safe for local usage.
Actual set as pictured above, this Bel Canto S300 Dual-Mono Stereo Audio Power Amplifier Set is in Excellent Condition & comes with the Original Manual and Box.
All Bel Canto products carry a 2 Year Warranty and this Set is still under warranty till Mid-Febuary 2018.
Payment mode will be on a C.O.D. basis.
This Bel Canto S300 Dual-Mono Stereo Audio Power Amplifier Set is currently in KL.
Collection can be done in JB, KL, Ipoh, Penang or Butterworth at no extra charge - for other collection locations, kindly contact me.
Shipping via PosLaju is also available. ( Item is Bulky.)
If you are interested, please Whatsapp +65-81666684 or respond via a PM
or send an e-mail with your contact number to
meridian-506@hotmail.com
Thank You for viewing my ad. Smile
meridian-506
Number of posts : 946
