Copland CTA 520 Power Amplifier
Post by p8balls on Tue Aug 22, 2017 10:22 pm
Good day to all,
I bought this on behalf of my brother, who has moved on to bigger and better gear (we all have this, its called upgrade-titis). It was bought off a very respectable seller here on hifi4sale (his equipment are all tip top in condition, big up to the man) and is in mint condition. I swapped it into my system for a listen and this review sings truth on the sound:
Summary from UHF magazine's review (issue no. 66): "The very best solid state amplifier Copland has produced, and by a long margin"
Copland's on description on this amplifier:
A two channel power amplifier in a slim line chasses. Combining the virtues of valve design with solid state circuit for high power stability and strong dynamics driving any speaker load with a clean undistorted signal.
Field effect transistors are used for both the input and driver stages. Like vacuum tubes they are voltage controlled and allow for circuitry design with a minimum of non-even harmonic distortion.
The CTA 520 remains faithful to the sound virtues of other COPLAND products. A firm grip on the lower octaves, an accelerating treble and most significantly a musicality, attributed to all COPLAND designs.
The specifications are as follows:
SPECIFICATION TABLE
Rated power 125 W / channel at 8 ohms
250 W / bridge or balanced operation
T.H.D.
Less than 0,05% at all levels
Frequence response
20-20 kHz - 0, 2dB
Input sensitivity 1,4V for rated power
Input impedance 50 K ohms (single ended inputs)
50 K ohms (balanced inputs)
S/N ratio More than 103 dB
Power consumption 600W
Nominal mains voltage 115V or 230V factory set for destination country only
Mains voltage range +/- 12%
Dimensions 430 (W) 86 (H) 390 (D) mm.
Weight 18 kg.
Condition: 8.5/10
Price: RM3000 RM2800 firm
Contact no.: zero one two - 2 six 7 six 9 six 7
Last edited by p8balls on Tue Nov 07, 2017 11:05 am; edited 2 times in total (Reason for editing : price reduced)
p8balls
Club Member
Club Member
Number of posts : 39
Registration date : 2015-04-07
Re: Copland CTA 520 Power Amplifier
Post by p8balls on Tue Aug 29, 2017 9:01 am
bumb
p8balls
Club Member
Club Member
Post by p8balls on Wed Sep 06, 2017 10:17 am
p8balls
Club Member
Club Member
Post by p8balls on Tue Sep 19, 2017 11:16 am
p8balls
Club Member
Club Member
Post by p8balls on Mon Oct 02, 2017 4:01 pm
p8balls
Club Member
Club Member
Post by p8balls on Wed Oct 11, 2017 8:56 am
p8balls
Club Member
Club Member
Post by redlibra on Thu Oct 12, 2017 5:23 am
Hi, I wrote to you in your inbox.
redlibra
Number of posts : 1
Registration date : 2017-10-12
Post by p8balls on Mon Oct 23, 2017 8:51 am
p8balls
Club Member
Club Member
Post by p8balls on Mon Oct 30, 2017 4:52 pm
p8balls
Club Member
Club Member
Post by p8balls on Tue Nov 07, 2017 11:05 am
p8balls
Club Member
Club Member
Post by p8balls on Tue Nov 14, 2017 9:02 am
p8balls
Club Member
Club Member
Post by p8balls on Tue Nov 28, 2017 11:31 am
p8balls
Club Member
Club Member
