Analysis Plus Oval One RCA Interconnect - 1m
Item: Analysis Plus Oval One RCA Interconnect - 1m pair
Condition: 8.5/10. Item in very good working condition.
Price: sold
For audiophiles who don’t need XLR connections, we developed the superb-value Oval One interconnect.
It uses a braided signal conductor in our proprietary hollow oval design along with a braided outer shield mated to a true 75 ohm RCA connector with a low-loss dielectric.
Because Oval One is handmade using first-rate materials, it will outperform other cables costing many times more.
The 100-percent shield coverage ensures the very low noise floor that’s essential to experiencing the entire dynamic range of symphonic music.
The RCA connection is solder-less, using a compression contact technique that spares the dielectric from damage that heat from soldering can cause. This technique also eliminates the poor signal transfer that results from a cold solder joint.
Our fussiness adds to the cost of the cable, but the performance increase is worth the added care.
Price: sold
Superb Value Handmade Interconnect
Enjoy "Increased Weight and Power" with Your MusicAudio components with balanced connections are justifiably praised for their performance potential. But Analysis Plus shows how far you can take the signal quality of an unbalanced system with its superb-value Oval One interconnect.
"I enjoyed the increased weight and power of the music, along with the system's improved transparency," reports the March 2002 issue of Good Sound! magazine. " Everything sounded just a little bit clearer and more refined."
Hollow Oval Conductor DesignOval One uses an oval braided signal conductor in its proprietary hollow oval design along with a braided outer shield mated to a true 75 ohm RCA connector with a low-loss dielectric. The patented hollow oval geometry controls current bunching and frequency effects for the truest possible sound.
Because Oval One is handmade using first-rate materials, it will outperform many higher-price cables. The 100-percent shield coverage ensures the very low noise floor that's essential to experiencing the entire dynamic range of symphonic music.
The RCA connection is solder-less, using a compression contact technique which spares the dielectric from damage that heat from soldering can cause. This technique also eliminates the poor signal transfer that results from a cold solder joint. The performance increase is worth the added care.
And It's "Priced Reasonably," TooAccording to Good Sound!, Oval One is "well-built, attractively designed, and, perhaps most importantly, priced reasonably enough that the cost of this upgrade is easy to justify.
Thank you.
» Analysis Plus Oval 1 RCA interconnect 1m
» Analysis Plus Oval One -RCA Interconnect (Sold)
» Analysis Plus Oval 1 RCA interconnect 1m (Used)SOLD
» Analysis plus Copper oval in interconnect cable (Used)
» Analysis Plus Solo Crystal Oval Interconnect
