Sherwood AX-7010R
Sherwood AX-7010R
Post by jemi on Sat Sep 16, 2017 7:35 pm
Sherwood AX-7010R
RM500
Semenyih
whatsapp/call 010 5464 349
this unis was probably top of the range on its time
110 watt perchannel (8 ohm), 140 watt (4ohm)
Got MM and MC selector for phono
Good working condition
review & specs (copypaste from net):
SHERWOOD AX-7010R
GREAT AMERICAN INTEGRA
HIGH RATING POWER 155 WATT / 4 OHM !!!
SOLID AND POWERFUL HIFI AMPLIFIER
To sell an excellent model of the American company Sherwood amplifier.
The AX + 7010R is probably the highest model of the series, a great sounding and solid audio amplifier.
It's also one of Sherwood's most powerful amplifiers.
It has a powerful power rating of 155W per channel at 4 ohms.
In the middle of the huge 740 Watt power transducer, 8 large Sanken power transistors (4 per channel), mounted on a large heatsink, for the purity and sound dynamics of the 2 large capacitors that provide adequate current efficiency and crystal and dynamic sound.
The power that allows you to calmly run practically any set of columns and to broadcast a large room or room size.
As far as performance is concerned, the amplifier is very solid, weighs about 12kg, the front panel is made of thick aluminum, uses a high-end gramophone preamplifier with a choice of insert type, and solid rear speaker terminals.
Front front panel with ergonomically positioned Bass, Treble, Balance control, source and recording selectors, centrally located large volume control knob, Loudness, Direct function (for shorter signal paths for better clarity), Subsonic filter and Mute function. Also switch selector sets column A or B, A + B and headphone output.
On the back of the RCA / Cinch input, dual gold plated phono midrange for PHONO MM and PHONO MC inserts, gold plated CD, AUX, TUNER, TAPE-1 / DAT, TAPE-2 / DVD, and additional EXT / ADAPTER input solid speaker terminals for connecting four columns A and B that can work together or separately.
The sound is lively, retail, based on the large but well-controlled bass, and with loud listening it does not mix with the rest of the strings. The mountain is clear but does not dominate.
Outstanding stereophony and full-fledged music scene with all the details, here is nothing to listen to the listener in one word excellent amplifier.
Perfect candidate for home audio HiFi with a robust and powerful Audio Amplifier.
Technical data
Powerful American Amplifier!
Thick aluminum front panel
PHONO, CD gold plated inputs
Rated output power: 2 x 155 W (4ohms)
Rated output power: 2 x 110 W (8 Ohm)
Music power: 2 x 190 W (4ohms)
Total Distortion - 0.05%
Frequency range: 5 Hz - 80 kHz
7 RCA audio inputs (cinch)
Special EXT / ADAPTER input for easy audio equalizer input
Built-in very good low-noise phono preamplifier
Separate, separate gramophone inputs for MM inserts and separate for MC
Adjusting bass and treble - Bass, Treble
Balance adjustment
Lowest and Highest Volume - Loudness
Ability to shorten the signal path to improve sound clarity - Direct
Lowest frequency filter below 20 Hz - Subsonic.
Possibility to connect columns with impedance from 4 - 16 Ohm
Speaker selector switch A, B, A + B
System Voltage Control that controls the operation of the amplifier and protects the loudspeaker and amplifier from damage
Solid, twisted speaker terminals
Headphone output
Possibility of remote control - unfortunately the remote control is not included
Dimensions: 440 x 125 x 330 mm (W x H x D)
Weight of nearly 12 kg
Last edited by jemi on Sat Sep 16, 2017 7:38 pm; edited 1 time in total (Reason for editing : add picture)
jemi
Regular
Regular
Number of posts : 52
Registration date : 2012-02-17
