Choseal Flat Speaker Wire
Choseal audio speakers line made a superb wire process, from imported PVC, oxygen-free copper inside (OFC) conductor & aerospace grade polyethylene (LDPE) / PVC insulation,
The high-fidelity design with anti-interference ability to enhance the transmission signal by using good effect and easy to use soft wire. Widely used in home decoration, audio-visual equipment connection, engineering, installation, car audio, electronic fields and so on.
Can be used for both front speaker or surround speaker wire.
The advantage of this flat speaker wire is that it makes excellent surround speaker wire and can easily fix in place using even double sided tape on walls or floor.
Product Name: Choseal Q-170
Type: Flat speaker wire 99.99% OFC copper
Conductor : (22 strands/ each * 4C) oxygen-free copper * 2C
Jacket: PVC Outer Diameter (OD) 12.8mm * 2.2mm thick paintable
Length: 100 m
Printing : There is printing on the speaker wire jacket to indicate the length.
Color: Yellowish White
This wire have an equivalent gauge of AWG 14 making it excellent choice for superb audio performance over most other brands in the market which have higher gauge of AWG 16 and above. Lower AWG means thicker copper wire means better performance over long cable run.
Why pay more for equivalent performance cable? Get equivalent performance cable without burning holes in your pocket.
To read more on Choseal company visit here
Contact : (Whatsapp or SMS) : 0122163733
Serious buyer only.
Kindly make appointment with me if interested.
Item Location : Subang Shah Alam
Price : RM6 per meter for loose buy
Price for 1 roll (100m) : RM550 (works out RM5.50 per meter)
Can sell in your required cut length based on the price per meter as above
Quick grab now selling fast only last roll of 100m available.
Length: 100 m
Serious buyer only.
cssam5229- Frequent Contributor
- Number of posts : 1752
Registration date : 2015-05-06
» Flat Wire speaker cables
» Choseal Bi-Wire Speakers Cables (SOLD)
» Straight Wire Super Quad 12/4 Bi-Wire Speaker Cables, 12'5" m pair (Used) SOLD
» Choseal speaker cable
