Marantz AV8801 AV Pre Amp/Processor & 8 Channel Power Amp (MM8003)-Used & In Good Condition
2 posters
Both in a very good working condition due to less use. Together with original remote with backlight and display (still new inside plastic).
Both are flagship model from Marantz few years back. Processor was around RM12k++ earlier. Power was around RM10k++
Made in Japan Processor with a better build quality and copper chassis internally.
A very good combo and matching setup to own. Both with RCA & also XLR connections for a better clarity and pure signal transmission.
Features:
- 4k/2k Video: Displays are here and content is coming and the AV8801 is ready.
- 4-port Ethernet Hub: This built-in hub can be used for Ethernet-based products like set-top-boxes, gaming consoles, and Blu-ray players and eliminates the hassle of installing a 3rd party hub.
- HDMI 6+1 in/ 2+1out (Dual HDMI out & Zone out): More devices feature HDMI outputs, and with a total of 7 HDMI inputs the AV8801 can easily handle all of your different source components. With a two zone matrix HDMI output, you now have true two zone capability. There is also a 3rd HDMI output that will mirror the output of the main zone.
- InstaPrevue: Remember "picture-in-picture"? InstaPrevue allows the end user to preview content on each of the HDMI inputs.
- Three Zone Audio: Each of the three audio zones can be controlled via IR, IP/App and/or RS232.
- Integration: Because Marantz has strategic partnerships with all of the major control companies, you can be assured that both RS232 and IP protocol will be both reliable and lightning fast.
- Shallow depth chassis, DC triggers, discrete IR commands and IR flasher inputs are among the features incorporated to insure that the installation goes
Looking inside MM8003 Power Amp one can see the heavy copper plated steel chassis with an enclosed Toroidal Transformer with all the parts carefully laid out to maximize performance.
Each of the MM8003’s 8 channels is rated at 140 watts with less than .08 percent total harmonic distortion with a signal to noise ratio of 105dB. The power supply providing the juice for all of this is includes a multiple-secondary toroidal transformer rated at 600VA and 100,000 microfarads worth of custom-designed capacitors.
The capacitors are mounted on copper-plated, anti-vibration brackets. Many of the key components are from well respected manufacturers of audiophile grade components such as WIMA.
Features
140W x 8ch (8 ohms) Power AmplifiersLow Impedance Continuous Drive Capability
Current Feedback Amplifier Circuit
Massive Toroidal Power Transformer
Slow Start to Power On (better protection for the amp and processor unit as well).
8ch XLR Input Terminals
DC Trigger Control Inputs, DC Power Status
Outputs, IR Flasher Input Terminals
Output Channel Relay On/Off Control
by Remote Signal (to Multi Zone Use)
Copper Plated Chassis
Gold Plated Speaker Terminals
Marantz Designed Storage Capacitors for Quick Response to Rapidly Varying Sources
New Clean Design Front Panel
Really good for both audio and video use.
Well maintained in smoke free and pet free environment.
Condition: 8/10 only due to no box, both sets are in tip top condition working condition.
Many award winning model, please check the reviews and more info below:-
https://hometheaterreview.com/marantz-av8801-av-processor/
http://www.audiogurus.com/marantz-av8801.html
http://www.avrev.com/home-theater-power-amplifiers/multi-channel-amplifiers/marantz-mm8003-power-amplifier.html
Amp is in Penang but can arrange delivery to other locations.
Contact: Anand 012-5885270
Please sms or whatsapp for more photos and other info
Price:RM7500 for both units (nego)
Last edited by anandfm on Mon Oct 16, 2017 7:50 am; edited 1 time in total (Reason for editing : Update photos)
anandfm- Frequent Contributor
- Number of posts : 969
Re: Marantz AV8801 AV Pre Amp/Processor & 8 Channel Power Amp (MM8003)-Used & In Good Condition
how much for mm8003?
naechte- New Member
- Number of posts : 5
Registration date : 2010-10-14
» Marantz 8 Channel Power Amp (Top Flagship Model)-Used & In Good Condition
» Marantz MM7055 5-Channel Power Amplifier in Good Condition
» Marantz AV8003 pre amp/processor (used & in good condition).
» Marantz AV8003 & MM8003 processor/power amp (Used)
» Marantz Flagship Model MM8003 Power Amp Made in Japan (used & in great condition)
