Mordaunt Short England 903i Bi Polar surround speakers
The 903i surrounds used here are bipole models, fitted with smaller 10cm mid/bass drivers and matching tweeters. Their unusual design provides a more even dispersion of rear sound effects and achieves a subtler surround performance. They can easily be wall mounted via the keyhole slot at the back.
Details
For those putting together a specialist home theatre system, bipolar rear channel speakers, such as the Mordaunt Short 903i Bi Polar speakers are essential, spreading the special effects accurately and naturally around the room. With their 10cm aluminium CPC drive units, cabinet size is kept to a minimum, allowing discreet positioning of these speakers. Discrete styling and versatility of placement allows the Mordaunt Short 903i Bi Polar speakers to be easily mounted on a wall or shelf unit.
Superb sound distribution over a wide listening angle envelops all listeners, recreating the cinema experience in your living room wherever you position the speakers. Mordaunt Short Distributed Surround Bi Polar configuration mimics the multi speaker installations in movie theatres for all-enveloping surround action.
With its slim profile that allows discreet shelf or wall mounting, the Mordaunt Short 903i Bi Polar twin speaker provides an ideal combination of good dispersion for Dolby Surround and precise rear effect localisation for Dolby/DTS sources, this speaker also presents an easy amplifier load that suits all types of amplification.
The Mordaunt Short 903i Bi Polar speakers can be easily mounted on a wall or shelf unit and distributes sound over a wide listening angle.
•Curved baffle Enhances dispersion over a wide seating area.
•Inverted option can be placed at ceiling level if required
•10cm aluminium CPC drive units
•Twin drive Base drivers and HF units provide the Bi Polar axis.
•Available in Black, Honey Maple or Calvados
Specifications:
Avant 903i bipole
Frequency response (Hz) 120-20k
Sensitivity 87db
Nominal impedance 4-8Ω
Power rating 15-100watts
(2) 100mm (4") aluminium CPC mid/bass
(2) 25mm (1") aluminium dome tweeter
X-Over type 2nd order damped LF 1st order HF
Dimensions (h x w x d)
230 x 218 x 150mm (9 x 8.6 x 5.9")
Weight 2.86kg (6lbs)
Available Finishes Calvados
Price : RM 850
- Number of posts : 2967
» (SOLD)Mordaunt Short Avant 903i Surround Speakers
» Mordaunt Short Avant 903i Bipole Surround Speakers 。(Used。)~2pair ~Both Sold.
» Mordaunt Short MS 302 Surround Speakers 2Pair (Used) SOLD
» Mordaunt-Short Avant 903i speakers (Used)
» Mordaunt Short Avant 903i BiPolar Speaker (Used) SOLD
