Marantz AV7703 11.2 Channel & Marantz 8 Channel Power Amp
Post by anandfm on Sat Oct 28, 2017 3:14 pm
Marantz AV7703 11.2-Channel AV Processor &  Marantz 8 Channel Power Amp (Top Flagship Model)
Used and in good condition.
AV Pre Amp just around 6 months old with warranty from supplier together with full complete set and in brand new condition.
Superb Dolby Atmos & DTS-X surround sound performing amp, can upgrade to Auro 3D also.
The AV7703 is Marantz's latest and most full-featured AV processor. At $2,199 it is just over half the price of the flagship AV8802A, yet it has several features not found on the flagship processor.
The AV7703 is an 11.2-channel processor with a full feature list that includes: Dolby Atmos and DTS:X; lots of connectivity options (including WiFi, Bluetooth, and Ethernet); built-in hi-res streaming capabilities (including TIDAL, Pandora, AirPlay, Spotify, SiriusXM, and more); built-in HD Radio and AM/FM tuners; 32-bit/192-kHz D/A converters on all channels; Audyssey MultEQ32; eight HDMI 2.0a inputs with HDCP 2.2 that support pass-through of HDR and BT.2020 color; and ISF certification.
Marantz 8 Channel Power Amp (MM8003).
High grade top flagship model power amp from Marantz, can say still best performing amp compared with some current power amps with lesser quality build in the market.
In a very good working condition due to less use. This Power Amp was around RM10k++ earlier.
With RCA & also XLR connections for a better clarity and pure signal transmission.
Looking inside MM8003 Power Amp one can see the heavy copper plated steel chassis with an enclosed Toroidal Transformer with all the parts carefully laid out to maximize performance.
Each of the MM8003's 8 channels is rated at 140 watts with less than .08 percent total harmonic distortion with a signal to noise ratio of 105dB. The power supply providing the juice for all of this is includes a multiple-secondary toroidal transformer rated at 600VA and 100,000 microfarads worth of custom-designed capacitors.
The capacitors are mounted on copper-plated, anti-vibration brackets. Many of the key components are from well respected manufacturers of audiophile grade components such as WIMA.
Features
140W x 8ch (8 ohms) Power Amplifiers
Low Impedance Continuous Drive Capability
Current Feedback Amplifier Circuit
Massive Toroidal Power Transformer
Slow Start to Power On (better protection for the amp and processor unit as well).
8ch XLR Input Terminals
DC Trigger Control Inputs, DC Power Status
Outputs, IR Flasher Input Terminals
Output Channel Relay On/Off Control
by Remote Signal (to Multi Zone Use)
Copper Plated Chassis
Gold Plated Speaker Terminals
Marantz Designed Storage Capacitors for Quick Response to Rapidly Varying Sources
New Clean Design Front Panel
Really good for both audio and video use.
Well maintained in smoke free and pet free environment.
Condition:8/10
Many award winning model, please check the reviews and more info below:-
http://www.avrev.com/home-theater-power-amplifiers/multi-channel-amplifiers/marantz-mm8003-power-amplifier.html
https://hometheaterreview.com/marantz-av7703-112-channel-av-processor-reviewed/
Amp is in Penang but can arrange delivery to other locations.
Contact: Anand at 012-58855270
Please sms or whatsapp for more photos and other info
Price:RM12500 (nego) more than RM20k for this combo set earlier.
anandfm
Number of posts : 337
