Micromega M-One Integrated Amplifier (Showroom Unit)
Micromega M-One Integrated Amplifier (Showroom Unit) Empty Micromega M-One Integrated Amplifier (Showroom Unit)
Post by WTL_Trading on Tue Oct 31, 2017 10:13 am
CLEARANCE STOCK !!!
PRICE : RM 16,000.00 (Showroom Unit)
ACTUAL PRICE : RM 20,500.00
The Micromega M-One M-100 amplifier has been designed to power the most demanding speakers and offer its user very high-end streaming and digital-to-analog conversion functions. It can have an optional self-calibration system, to fit any listening room. It's a class AB model.
A real feat of engineering. The French brand Micromega offers the Micromega M-One an amp perfectly in tune with modern musical listening. Powerful, with up to 2x200 W at 4 Ohms, the Micromega M-One has a plethora of digital inputs, to exploit current or high-end sources: HDMI I2S, asynchronous USB, S / PDIF. The on-board DAC is compatible with PCM streams up to 32 bits and 768 kHz, as well as DSD (native, DoP) up to 11.2 MHz. There is no optical drive or network with which the Micromega M-One M-100 will not communicate. Note that the DAC is an Asahi Kasei AK4490, the current digital-to-analogue converter of reference.
The DAC Micromega M-One M-100 also features an aptX-compatible Bluetooth receiver and Ethernet network controller to function as a DLNA rendering device. In other words, playback of audio files, CD quality as HD studio is allowed from a computer, a NAS or Android tablet for example. A Micromega mobile app for Android and iOS is available to listen to other sources (Internet radio, etc.). In addition, the Micromega M-One M-100 is AirPlay compatible with AirDream technology.
The DAC Micromega M-One M-100 is equipped with a full analog preamp section, with RCA and XLR line inputs, and an RIAA preamp, which is compatible with mobile magnet (MM) phono cells. voice coil (MC). A pre-out XLR output and an RCA format for active subwoofer are also present.
The DAC Micromega M-One M-100 amp can optionally include a self-calibration system called MARS, which automatically adjusts the listening parameters to the acoustic characteristics of the listening room: if it causes a delay on certain frequencies, it will be compensated. Same for a shortfall in a frequency range. The MARS option can be added later to the device.
The DAC Micromega M-One amp is made of solid aluminum and offered in several colors, matt or lacquered. A beautiful integrated amp made in France.
Micromega M-One Integrated Amplifier (Showroom Unit) 22712310Micromega M-One Integrated Amplifier (Showroom Unit) Ban-mo10Micromega M-One Integrated Amplifier (Showroom Unit) 22554810Micromega M-One Integrated Amplifier (Showroom Unit) 22768210
Amplifier size
Width : 430 mm
Depth : 350 mm
Height (with spikes) : 56 mm
Amplifier weight
Net weight : 9 kg
Gross weight : 10,7 kg
Packaging (overbox)
Width : 735 mm
Depth : 600 mm
Height : 150 mm
Packaging (box)
Width : 685 mm
Depth : 542 mm
Height : 85 mm
Power Consumption
Standby : 1W
2 channels -1/8 Pmax under 8 Ohms : 140W
Rated output power
PRMS under 8 Ohms : 2*100W
PRMS under 4 Ohms : 2*200W
Signal to noise ratio
Digital input : 106 dB(A)
Balanced analog input : 103 dB(A)
Unbalanced analog input : 100 dB(A)
Phono MM input : Higher than 75 dB(A)
Speaker output residual noise, open input
8 Ohms : under 160 µV
4 Ohms : under 200 µV
Output impedance @250Hz under 8 Ohms 15mΩ
Damping factor Sup. à 500
Total harmony distorsion
THD, 8 Ohms, 63 Hz : under 0,001%
THD, 8 Ohms, 1 kHz : under 0,005%
THD, 8 Ohms, 10 kHz : under 0,05%
THD, 4 Ohms, 63 Hz : under 0,001%
THD, 4 Ohms, 1 kHz : under 0,01%
THD, 4 Ohms, 10 kHz : under 0,07%
Intermodulation distorsion - SMPTE
IMD, from 1W to PNOM, 8 Ohms under 0,01%
IMD, from 1W to PNOM, 4 Ohms under 0,02%
Intermodulation distorsion - Dynamic
DIM 30, 50W, 8 Ohms under 0,02%
DIM 30, 100W, 4 Ohms under 0,05%
Channels separation
Crosstalk, 1kHz under 96dB
Crosstalk, 10kHz under 80dB
Analog input sensitivity
Phono MM, 47 kOhms 12 mVRMS
Phono MC, 110 Ohms 1,2 mVRMS
Analogue : 1,4 VRMS
Balanced : 1,7 VRMS
Sub-out output
Cut-off frequency : 400
 (SHIPPING NOT INCLUDED)
Please contact us at 012-614 3049 (Ms Wee) or 016-725 5372 (Wendy) for further details or pricing or to arrange for a demo at our showroom situated at Taman Melaka Raya, Melaka.
Mode of payment :
- COD anywhere in Malacca town area / our showroom
- PBB for purchase made outside Malacca.
WTL_Trading
Number of posts : 359
Registration date : 2016-06-29
Micromega M-One Integrated Amplifier (Showroom Unit) Empty Re: Micromega M-One Integrated Amplifier (Showroom Unit)
Post by WTL_Trading on Wed Apr 11, 2018 3:09 pm
WTL_Trading
Post by WTL_Trading on Wed Oct 24, 2018 10:05 am
WTL_Trading
Post by WTL_Trading on Mon May 27, 2019 11:37 am
BUMP
WTL_Trading
