APS Cable Elevators - Making a Difference
Post by superfi on Fri Nov 03, 2017 5:24 pm
Cable Elevators are very affordable & inexpensive upgrades which will work on your inter-connects, power cables, speaker cables, etc to raise them from any surface that they are currently lying on.  By moving cables away from surrounding surfaces the negative dielectric field interaction or "boundary effect" is removed, preserving the delicate audio signal's purity.
Cable Elevators will:
  • Reduce harmful effects of floor-borne vibrations (sound or movement
  • Improve dielectric field constant by isolating cables or keeping them
    separate from nearby cables
  • Minimize unwanted interaction between power and signal cables
  • Facilitate proper organization of audio cable & inter-connects - looks good, sounds even better!
Our APS Cable Elevators are cut from high quality acrylic of 25mm thickness and polished to a shine. Acrylic is an ideal medium because of its inert nature and sound wave absorbing qualities. The Cable Elevators come in 2 models with dimensions of:
     100 mm (W) X 60 mm (Height) - Normal lift of 6 cm
     100 mm (W) X 80 mm (Height) - Those requiring higher lift of 8 cm
 (Left at 60mm height / Right at 80mm)
Sold in economy sets of 16 pieces at RM300 per set of either height or a mix of 60mm & 80mm as per your specific requirements.
Call 03-76104466 or 011-39300083 for Greg.  Shipping can be arranged.
PS:  Please also see our other products on discount at the Section on Audio & Video Equipment for Sale (New or NOS) in the same blog (go to Home, 2nd Major Subject title)
Number of posts : 292
