SANSUI S-7XV Floor Stand 3-Way Speaker System
SANSUI S-7XV tallboy speaker system carries an AASW (Aero Acoustic Sub woofer) system corresponding to audio video.
It’s magnetically shielded. Friendly too as AV floorstand
http://audio-database.com/SANSUI/speaker/s-7xv-e.html
3-Way 3-Speaker system
AASW system is by a 6.5″ woofer unit adopted, aiming at the bass play which is equal to a large-diameter unit, it is a bass playback system based on the resonator theory of the helmholtz.
The vibration which has gained low-pass sufficient sound pressure and is generated here by having the resonance frequency of an internal space and a duct part in low-pass.
The role of the acoustic filter was also played, when coming out from a duct, the harmonic content was eliminated, and little distorted play sound has been obtained compared with the direct sound scheme.
1-inch (25cm) hard dome tweeter is adopted, plus a 6.5-inch (16cm) cone type Woofer and a high region low-pass of another 6.5-inch driver.
The interior of a cabinet secured sufficient board thickness, and has prevented the unnecessary box resonance so that a low-pass part may not affect a main system part.
Frequency Range 38Hz – 20kHz
8 Ohms
Sensitivity of 86dB
Crossover frequency at 65Hz and 3000Hz
Dimension: W250 x H1064 x D309 mm
Weight of 20KG
Made in Japan
High quality crossover parts
Unique design of the speaker enclosure, consists of 2 internal parts separately as sub bass chamber and higher frequency.
Such design creates a cleaner 3-way sound reproduction system.
Good condition, in perfect working order.
Welcome for audition.
RM990
Credit card accepted.
Subang Jaya ss14
Contact O16 440714O
Belows are real item pictures:
8 Ohms
Sensitivity of 86dB
Weight of 20KG
Made in Japan
RM990
Subang Jaya ss14
Contact O16 440714O
mav- Frequent Contributor
- Number of posts : 282
Registration date : 2010-09-21
Re: SANSUI S-7XV Floor Stand 3-Way Speaker System
Still available
Cash / Credit Card accepted
Stil available
credit card acceptable...
Location @Subang ss14
Still available
Contact 016 44O7140
» SANSUI S-7XV Floor Stand (Sold)
» XTZ 99.38 MKII 3-Way Floor Stand Loudspeaker [Price Reduce]SOLD
» Rogers ls 108 floor stand speaker.
» Focus SA5 Floor stand speaker.
» (SOLD)Used acoustic research 312ho floorstand spk (accept trade in)
