Dali Opticon Vokal (Sold)
2 posters
Ribbon tweeter for superb vocal reproduction
The Opticon Vokal uses a ribbon tweeter paired with a more conventional dome tweeter for sensational results. With the ribbon tweeter handling the very highest frequencies - most of which can't even be heard by the human ear - the conventional tweeter is freed up to handle lower frequencies. This means less harmonic compression and a high frequency that can 'breathe'. What you hear is an effortless treble performance full of rich detail and free from harshness.
Audiophile-grade drive units for the finest sound
Matching up with the impressive tweeter array, the Opticon Vokal also features a low-loss, wood fibre woofer that's based on Dali's reference grade Epicon speakers. This high quality woofer offers low distortion and a natural reproduction for sound exactly as the director intended.
Dali in-house cabinets made to the highest standards
Rather than 'buying in' cabinets, Dali produces the Opticon cabinets in-house. This means they can be sure of the quality and consistency of build. The solid cabinets have been designed for low levels of resonance, giving low distortion and helping to promote a natural sound. Front-firing bass reflex ports make the speaker more efficient and also allow it to be easily placed in a TV cabinet without adversely affecting the sound. Finished in black, white or walnut, there's a cabinet finish to match your decor.
Don't compromise on the quality of your home cinema dialogue. Hear it as it was meant to sound with the Dali Opticon Vokal.
Dimensions WxHxD (mm)
435 x 201 x 312mm
Freq Response (Hz)
47 - 32000
Impedance (ohms)
4
Power Rating (Watts)
150
Sensitivity (dB)
89.5
Speaker Enclosure Type
Bass reflex - front port
Weight (KG)
8.8
Colour
Walnut
Conditions: 9/10
RM 1,400 (Sold)
Interested please Whatsapp +61 484 198 696
Last edited by seasky on Tue Apr 16, 2019 2:43 am; edited 1 time in total (Reason for editing : Sold)
seasky- Frequent Contributor
- Number of posts : 151
Registration date : 2016-12-18
Re: Dali Opticon Vokal (Sold)
A very good quality center speaker at this price point!
How old is this speaker? Any issues so far on this unit?
anandfm- Frequent Contributor
- Number of posts : 969
Impedance of 4 ohms? Is it difficult to drive with regular AV amps?
Hi Anandfm,
The speaker is 6 months old nothing wrong with it and use it only for 1 month then upgraded to Usher BE-616 DMD center. So far it works fine with my Marantz SR7011 AV amp. Defintely it will sound better with power amp.
Single woofer design, avoid the comb filter problem but the soundstage is not that big.
a good center speaker
» Dali opticon vokal center speaker
» Dali Opticon 5 Floorstand Speakers(Used) - SOLD
» Dali Ikon Vokal 2 SOLD
» Dali Opticon LCR Wall Mount Loudspeaker (Sold)
» Dali Zensor Vokal Speaker (sold)
