Dali IKON 1 Denmark Made Ribbon Tweeter Bookshelf Speaker ( White)
Post by HiFiLab on Sat Nov 18, 2017 9:10 pm
Personal preferences are a highly subjective thing and can by definition only be judged
individually. You may “like” the sound of one speaker more than another, but when it
comes to getting things right, it is no longer a matter of personal taste. It is either right
or wrong.
Our mission with DALI IKON has been to get things right, not to “tweak” the sound to
sugar-coat a particular style of music or to match any personal preferences. We designed
DALI IKON to deliver the truth, the whole truth and nothing but the truth. And we are proud
to declare: “Mission accomplished.”
DALI IKON redefines musical realism at its price point, handling a wide range of music
in a natural, powerful, dynamic manner. This level of resolution and transparency reveals
everything about the contents and quality of any recording.
But we know that this kind of uncompromising honesty is not for everyone. Can you
handle the truth?
DALI IKON can
Made In Denmark
Our IKON loudspeaker is developed, designed, built, hand-assembled and individually
tested (no robots, no assembly lines) in Denmark at our own state of the art R&D and
production facility. In the out-sourced, sub-contracted world we live in, this is a rare thing
and it is your added assurance that everyone involved in the making of your loudspeakers
shares the same commitment, dedication and enthusiasm.
Enjoy!
Hybrid tweeter module | 5" bass/mid driver | Single
wiring terminals | 43-30,000 Hz | H350 x W150 x
D260 | 5.2 kg
If you prefer music from a very compact
speaker, you should definitely consider IKON 1.
Unlike many other compact speakers, you can
expect great performance from the IKON 1.
The speaker is designed to perform optimally
when wall-mounted or placed on a bookshelf.
Like most of our speakers, IKON 1 is a great
choice both for a compact stereo setup or a
compact surround sound setup.
The 5" mid/woofer has enough cone area to
play relatively deep bass - even at relatively
high sound pressures. A compact version
of the hybrid tweeter module reproduces the
highs with great detail and clarity - in part due
to the use of an extremely powerful neodymium
magnet.
IKON 1 has single wire binding posts on the
rear side together with built-in wall mount
bracket making installation a very easy task.
Small in size. Big on performance. The forward-firing dual bass reflex ports of the IKON 1 allow discrete placement on a bookshelf or wall (brackets included) without muffling bass output. This little jewel also has an amazing ability to make itself virtually disappear – leaving just you and the music.
SPECIFICATIONS
Product Series IKON MK1
Speaker Type Front
Frequency Range (+/-3 dB) [Hz] 43 - 30,000
Sensitivity (dB, 1 W @ m) (dB) 87
Nominal Impedance [Ω] 8
Maximum SPL [dB] 106
Crossover Frequency (Hz) 2,900/14,000
Bass Reflex Tuning Frequency [Hz] 47
Enclosure Type Bass Reflex
Recommended Placement  Shelf/Wall (bracket incl.)
Soft Dome Tweeter (mm, diameter) 28
Ribbon (HxW, mm) 45 x 17
Drivers Mid/Woofers 1 x 5"
Magnetic Shielding Yes
Dimensions (HxWxD) (mm) 350 x 150 x 260
Connection Inputs  Single-wiring
Weight (kg) 5.2
Finish
White
In good working condition,
Price : RM 1450
Last edited by HiFiLab on Sat Dec 02, 2017 11:44 pm; edited 3 times in total (Reason for editing : add info)
HiFiLab
Number of posts : 2133
BUMP
Post by HiFiLab on Sat Dec 02, 2017 11:45 pm
HiFiLab
