Eminent Technology LFT8 B
Post by advance audiophile on Sun Nov 19, 2017 11:41 pm
The magnetic drive principle developed by Eminent Technology for the LFT speaker series is unique to the industry. As the diaphragm of the speaker moves between the magnets following an audio signal, the magnetic field remains constant. In a sense, it is the magnetic equivalent of a push-pull electrostatic loudspeaker, differing in that it requires no step-up transformer or bias voltage and that the audio signal is applied directly to the diaphragm.
In order to obtain a uniform driving force over the entire surface area of the diaphragm, a low mass foil/mylar diaphragm is used with conductor traces etched (like a circuit board) with high resolution. The large surface area of the midrange driver gives excellent power handling capacity. A thin lightweight diaphragm is utilized for the high frequency driver.
The LFT-8b minimum recommended amplifier is 50 watts/channel. The maximum recommended power is 200 watts/channel. The speaker is moderately efficient and its impedance averages 8 ohms.
The low frequency woofer was carefully designed to blend seamlessly with the mid-range and high-frequency drivers. The design uses a very low crossover frequency (180Hz) between the woofer and midrange. The woofer has a very high complince and operates with a near critically damped system Q of .58. This tuning insures excellent transient response.
The panels are attached to a rigid steel frame to prevent resonances. The woofer is mounted in a rigidly braced enclosure.
Selling at RM6800 only very good condition selling because moving out soon, please call 012-3282993
advance audiophile
Number of posts : 575
