What could be the problem?
Post by larren on Fri Mar 19, 2010 8:03 pm
Your advise and experience needed.
My integrated amp have this symtom lately. The volume/sound from the right channel will be softer and sometime totally mute while playing TT or cd. This happens mostly when the 'source direct' button is push to off. What I normally do to bring back the sound level back to normal is to play around with the 'source direct' (on and off) button.
By the way, my int amp is about 10 years old.
Thank you.
larren
Club Member
Club Member
Male Number of posts: 37
Registration date: 2010-01-29
Re: What could be the problem?
Post by azri on Fri Mar 19, 2010 8:16 pm
it can be the button itself or leak on caps. better off take it to qualified technician becoz if its leak on caps than things can get even worse. cheers
azri
Male Number of posts: 1036
Registration date: 2009-01-21
Post by drife on Fri Mar 19, 2010 8:18 pm
contact? carbon build-up? is your amp on the floor or on the lowest tier of the rack? that area's dusty zone for me... used to have my gear on the floor but not anymore... sacrifice a bit of sound quality, for a teeny weeny bit of longevity. i really hate bad contacts, noisy switches and crackling-sounding knobs. your amp's prolly due for service/cleaning.
drife
Male Number of posts: 500
Registration date: 2009-07-18
Source(s): Teclast P81HD ICS 4.0.1
Amplification: Rockchip RK2918
Speakers: SGS2 IEMs
Post by atoz on Fri Mar 19, 2010 9:01 pm
Normally a can of contact cleaner is all you need!
the sellector button" yes the buttons! and the volume pot also,
no worry!
but make sure you swtich off mains before doing!
Easy as ABC
atoz
Male Number of posts: 138
Registration date: 2010-01-30
Post by mugenfoo on Fri Mar 19, 2010 9:24 pm
Now lets get back to addressing the REAL issue here:
When SOURCE-DIRECT is ON, no problem right ?
Only when SOURCE-DIRECT is Off, this means the signals will go thru the Bass, Treble (and maybe midrange if your amp has one) knobs and filter circuits. And therein lies the problem. Either these knobs have bad contacts, or the high-pass, or low-pass, or both filter circuitries have leaky caps or some misbehaving components. Or maybe the contacts of the SOURCE-DIRECT contacts are making bad contacts in the "OFF" positon. Either way, it's a simple fix. Can DIY if you're familiar with basic elec. circuits, or just leave it in the hands of the usual repairers. That dude in Old Klang Road (actually there're a few) who specialises in fixing hifi stuff could get it sorted out no sweat.
Try the contact-cleaner method first ... its easily DIY'ed at home.
Only if it doesnt solve the problem, then pay mr. Old Klang Road a visit...
mugenfoo
Male Number of posts: 2665
Registration date: 2009-04-04
Source(s): Marantz
Amplification: Exposure
Speakers: Harbeth P3ESR
Post by drife on Fri Mar 19, 2010 9:37 pm
good one mugen. ahh...no...pls dont send anymore to mr.oh u g. my gear's been there for the whole month.
drife
Speakers: SGS2 IEMs
Post by larren on Sat Mar 20, 2010 12:43 am
Thanks guys for all the replys.
larren
Club Member
Club Member
Post by larren on Sat Mar 20, 2010 12:55 am
atoz wrote:Normally a can of contact cleaner is all you need!
Errrr......just spray on those switches, knobs and etc and let them drip dry? Can I spray the cleaners on the PCBs?
This may sound silly but I just to confirm with you guys, does the contact cleaner dry by itself (evaporating) and no need to dry the components by wiping with a piece of cloth?
Thanks.
larren
Club Member
Club Member
Post by cmboy on Sat Mar 20, 2010 1:43 am
Why do you want to spray on PCB?. If its dirt, dust, use compressed air and blow it all out, like how I do it on PC motherboards. Spraying chemicals onto a PCB is generally a no-no.
(yes, I do own a air compressor for general purpose, so I have that very conveniently)
cmboy
Male Number of posts: 1163
Registration date: 2009-03-11
Post by CT-Boy on Sat Mar 20, 2010 7:57 am
Normally they are 'self drying' as they contains some petroleum based distillate and compressed carbon dioxide.
You spray them on contacts ie switches and the likes, not meant for PCB cleaning what so ever..
This might fix your problem if the SOURCE-DIRECT switch is at fault(contact problems). If it doesn't fix it then you know it could be the tone circuits.
Good luck!
[/quote]
Thanks.[/quote]
CT-Boy
Male Number of posts: 219
Registration date: 2010-01-24
Source(s): Technics SL-5
Amplification: Rotel RA-820
Speakers: Gale 3030
Post by drife on Sat Mar 20, 2010 11:23 am
el cheapo air comprssors go for about rm19.90 at the giant/brothers... i wouldn't know how strong they are though. hmm... wait a minute, i think these ones run off a 12v cigarette lighter socket. this one have to consult cmboy... but i've used a vacuum cleaner, not very efficient coz the tip's big but can do lah.
drife
Speakers: SGS2 IEMs
Post by CT-Boy on Sat Mar 20, 2010 12:04 pm
Those 'elcheapo' 12V compressors are for inflating them car tyres so they would go reasonable high pressures, a couple of bars I think.. don't recalled seeing any pressure regulators on them though.. using them directly for cleaning can be 'tricky'..
CT-Boy
Speakers: Gale 3030
Post by larren on Sat Mar 20, 2010 6:55 pm
Thank drife and CT-Boy.
larren
Club Member
Club Member
Post by CT-Boy on Sat Mar 20, 2010 8:23 pm
Not at all.
Personally I would go with a can (or two) of compressed air that are used by photographers. Multi usage on top of camera cleaning, PC, laptops and of course, electronics.
You can find both contact cleaners and the compressed air in Jalan Pasar.
CT-Boy
Speakers: Gale 3030
Post by drife on Sat Mar 20, 2010 9:00 pm
shait, it didn't cross my mind. the caps might come loose and fly off. i recently bought a used a usb powered keyboard cleaner, it wasn't strong enough. guess im gonna try air cans from jln pasar. thanks CT.
drife
Speakers: SGS2 IEMs
