Antique sound lab power mono block amp Hurricane sold
hi , i hv a pair antique sound lab hurricane
mono block power tubes amp
Award winning legendary performance of this very musical powerhouse has been further refined. legendary performance is now even better with improved circuit and select transformers.
inside using oil cabling capacity hand make .
condition 8/10
Output power: 200 Watts (pentode/tetrode mode). 100 Watts (triode mode)
Output impedance: 4, 8, 16 Ohms.
Input impedance: 100kHz.
Input sensitivity: 600mV 12 Hz – 41kHz. (At 1.0 Watt)
Frequency response: 18Hz – 30kHz. (At full power)
Frequency response: 0.3% (at 1 Watt)
THD: 5% at full power
THD: S/N: 88 dB (at full power)
Nominal Voltage gain: 50.46dB
Global NFB in dB: (0)
Dimensions: 350mm., 13 ¼” W X 350mm.,13 ¼” D X 325mm., 12 ½” H
Net weight:38 kg/each side
Selling rm sold,200.00 / pair .(neg)
power valves no need to change still like new working excellent.
no box no manual .
pls call ,sms, whtsappa , Ricky 0193379357
thanks for viewing ...
condition 8/10
no box no manual .
rickyhow123- Frequent Contributor
- Number of posts : 117
Registration date : 2017-01-17
» Antique sound lab hurricane mono block (used)sold
» Antique Sound Lab AV-20 Mono Block Power Amp ( SOLD )
» Antique Sound Lab AV 20 mono block (used)sold
» Antique Sound Lab Hurricane power amp (Used) SOLD
» Antique Sound Lab Hurricane (USED)(SOLD)
