(SOLD)B&W DM'305 n DM'302 prism system speakers
Ipoh, Perak
RM----SOLD
B&W Loudspeakers unveiled yet another innovative idea evolved within its R&D laboratories to join such earlier innovations as the Keylar drive unit cone and the Matrix enclosure. They call this new form of construction the Prism system and it comprises a plastic moulded back panel having many of pyramid-shaped spikes projecting into the cabinet expressly to break up, and hence reduce the undesirable coloration from internal standing waves. The system has no explicit genre priorities: both strict fan of classics and rock music fan will be satisfied by sound quality. The extraordinary appearance of DM305 will definitely find its admirer.
Specification B&W DM305
System type 2-way
Enclosure type Bass-reflex
Frequency response ± 3dB 55 - 20000 Hz
Nominal impedance 8 Ohm
Amplifier Requirements 25 - 120 W
Sensitivity (2.83V/1m) 91 dB
Tweeter 25 mm (1 in.)
Woofer 165 mm (6.5 in.)
Dimensions (H x W x D) 841 x 217 x 308 mm / 33.11 x 8.54 x 12.13 in.
Weight 11 kg / 24.2 lbs.
B&W DM302 bookshelf Specification.
Description: Two-way, reflex-loaded, stand-mounted loudspeaker.
Drive-units: 1" (26mm) soft-dome tweeter, 5" (130mm) pulp-cone bass/midrange driver.
Crossover frequency: 3kHz.
Frequency response: 72Hz-20kHz, ±3dB.
Sensitivity: 91dB/2.83V/1m.
Nominal impedance: 8 ohms (3.2 ohms minimum).
Power handling: 25-100W continuous.
Dimensions: 12 5/8" H by 71/4" W by 8 3/4" D. Weight: 9 lbs
EXCELLENT WORKING CONDITION.
speakers in mint condition NO SCRATCH OR DENTS.
(VIEW TO CONFIDE THE CONDITION N DEMO TO HEAR
THE PERFORMANCE). whatsapp 0143413655
Last edited by jbashok on Sun Jun 24, 2018 2:31 pm; edited 1 time in total (Reason for editing : SOLD)
- Number of posts : 2913
» B&W DM305 PRISM System Floorstand Speakers -sold
» Bowers & Wilkins (B&W) Prism Bookshelf Speakers DM302
» B&W DM302 Bookshelf Loudspeaker system (Used) SOLD
» B&W DM302 speakers (Used)SOLD
» B&W DM302 (SOLD)
» B&W DM302 (SOLD)
