MiniWatt S1 + Cambridge Audio S30 + Sony BM10 (Sold)
Post by zey on Sun Dec 24, 2017 10:21 pm
Price: SOLD
Contact: Zey - 012-3798137 (WhatsApp)
Condition: 9/10
Package Includes:
1. MiniWatt S1 Tube Amplifier
2. Cambridge Audio S30 Speakers
3. Sony BM10 Apt-X Bluetooth Receiver
4. QED Silver Anniversary Speaker Cables (Amplifier End c/w Banana Plugs)
5. JAN GE 5654W Pre-Amp NOS (New Old Stock - October 1983) Tubes (1 Pair)
6. Shuguang 6J1 Pre-Amp Spare Tubes (2 Pairs)
7. Shuguang 6P1 Power-Amp Spare Tubes (1 Pair)
Package Excludes:
1. RCA Intercomnects
Package Summary:
This is a very capable mini high fidelity audio system which sounds much bigger than its look. It is for hifi enthusiasts who might need a set to be placed in the bedroom or study room while able to stream from their wireless bluetooth audio source such as their mobile phone or laptop via Sony BM10 Apt-X lossless receiver. The MiniWatt S-1 tube amplifier delivers solid 2.5W/channel of ultra smooth sound using a pair of Mullard M8100/CV4010 pre-amp vacuum tubes coupled with a pair of Svetlana 6P1P-EV power-amp vacuum tubes. The pair of high sensitivity Cambridge Audio S30 speakers are driven effortlessly by this mini tube amplifier with enough of punch and clarity - a perfect match! If you wish to experience different sound signature, I'm throwing in spare tubes like JAN GE 5654W and Shuguang 6J1 pre-amp valves and Shuguang 6P1 power-amp tubes for tube rolling. I'm letting go this set at a very attractive price, so if you're serious and keen about it, do contact me!
MiniWatt S-1 Tube Amplifier:
Power Output: 2.5W+2.5W @ 8 ohms
Frequency Response: 30-20Khz (+-1db) Sensitivity = 500mV
Gain = 18dB
Residual Noise < 0.8mVac
Output Impedance: 8 ohms (Japan Z11- EI48*24
Output Transformers)
Input AC Voltage: 85-132Vac or 176-265Vac
Dimensions: 130 x 100mm
Weight: 1.5kg Input: RCA Jacks Output: Banana Jacks
AC: Standard IEC Jack with Fuse protection (2A Fuse)
http://www.highfidelityreview.com/miniwatt-s-1.html
http://www.tnt-audio.com/ampli/miniwatt_amplifier_e.html
https://positive-feedback.com/Issue46/miniwatt.htm
http://www.6moons.com/audioreviews/miniwatt/miniwatt.html
Cambridge Audio S30:
Sensitivity: 90dB
Frequency Response: 55hz - 20kHz
Nominal Impedance: 4-8 Ohms
Drive units:
Tweeter - 1 x 25mm (1”)
Woofer - 1 x 115mm (4.5") mid/bass driver
Crossover: 1st Order 2 way
Recommended maximum amplifier power: 100 watts
Ported: 1 Rear
Magnetically shielded: Yes
Dimensions (H x W x D): 226 x 160 x 235mm (inc. grill)(8.9 x 6.3 x 9.2”)
Weight: 3.75kg (8.3lbs)
Finishes: Black
https://www.whathifi.com/cambridge-audio/s30/review
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speakers/cambridge-audio-s30-956254/review
Sony BM10:
Features -
NFC – One-touch pairing/connecting
Pairing – up to 8 devices
Pairing/connecting options:
One-touch (NFC)
Bluetooth®️ pairing/connecting
Display and controls -
Connect key
LED (4 colours)
NFC mark
Compatible -
Bluetooth®️ enabled smartphones, tablets and computers supporting Bluetooth®️ Profile A2DP
https://www.techsling.com/2014/02/sony-bm10-bluetooth-music-receiver-review/
JAN GE 5654W
Shuguang 6J1
Shuguang 6P1
zey
Number of posts : 13
Registration date : 2009-12-30
