Small integrated stereo amp
Post by samazzah on Thu Jan 04, 2018 2:28 pm
Am looking for the above unit for sale. To be used with a small speaker with a 6.5” mid woofer that is reasonably Ok to drive but not easy. Possible candidates are Rega Elex-R, Audiolab, Cyrus, Arcam or Yamaha, Denon that does not have to be played so loud to hear good - can drive the speaker in other words. Reasonable price - not exotica ie. SET, gold plated etc.
Thanks for your attention albino
samazzah
samazzah
Number of posts : 105
Source(s): CA network streamer/Michell Gyro/OL Conqueror/ VDH Frog
Amplification: none -
Speakers: AVI ADM 40 actives
Re: Small integrated stereo amp
Post by STC on Thu Jan 04, 2018 3:19 pm
If you are okay with no name brand you can try
https://www.lazada.com.my/a960-100w-stereo-digital-audio-power-amplifier-aluminum-material-black-116036513.html?spm=a2o4k.prod.0.0.713efad0hiPvWr
I am using seven of this. Clean sound but meant for low volume.
Otherwise try Behringer A500. If your speaker impedence drop below 4 ohm than I would suggest CrownAudio XLS. Unfortunately, all these are not audiophile brand. You can get Behringer for RM700 + from Musicbliss.
STC
STC
Number of posts : 412
Registration date : 2010-08-15
Source(s): Ambiophonics setup.
Speakers: Electrostatics
http://goo.gl/CF1C6B
Post by samazzah on Thu Jan 04, 2018 4:24 pm
Ok thanks, will take a look
samazzah
samazzah
