Victor JVC M-3030 Stereo Duo-Mono DC Power Amplifier
Post by HiFiLab on Thu Jan 11, 2018 11:19 pm
Made In Japan
Description
Accuracy is the hallmark of the JVC M-3030 , its DC amp configuration assures minimum dynamic distortion, that kind of distortion which becomes apparent when an amplifier handles program material, ie music.
Power output: 100 watts per channel into 8Ω (stereo)
Frequency response: 1Hz to 100kHz
Total harmonic distortion: 0.05%
Damping factor: 75
Input sensitivity: 1V
Signal to noise ratio: 116dB
Semiconductors: 41 x transistors, 13 x diodes, 2 x FET
Dimensions: 420 x 166 x 300mm
Weight: 19.2kg
JVC M3030 後級
日製 .年代久遠. AB類後級.電源變壓器兩個,+-62V  兩對功率管並聯,輸出約150W . 箱子有模有樣電源變壓器兩個,重量十足.散熱片在前端,還有個LED當指示 側面可看到TO3 功率管 ,放大主板插在插座上. 電源供應兩組,前端穩壓一組. 殘留雜訊 1KHZ 輸出 背板有音量控制VR X2  喇叭輸出, AC電緣開關.
100W+100W(8Ω ), 重量 19.2 kg ( 46.8 Ibs. ) ,
每邊 4只龜殼= 總數 8只, + 4個大水塘, + 2個大方牛.
力水足。聲音耐聽
Price : RM 2150
HiFiLab
Number of posts : 2393
