Castle Harlech Floorstand
Post by Connoisseur77 on Sat Jan 13, 2018 4:17 am
Fully working order
Original Drivers(cones)
Cosmetic 7/10
Made in England
Solid cabinet with wood veneer built
Selling RM1350
Please call 011 2964 one thousand
Thanks
Castle Harlech - English two-way system with the original acoustic design. Speaker has three drivers: tweeter inch metal dome midrange and a pair of head diameter of 130 mm with polymeric conical diffusers. One of the conical speakers unexpectedly on the top panel. The inner space of the speaker is divided into two parts, the vertical panel. Adjoining the upper part volumes are independent exits through openings in the bottom of the speaker. Moreover, inside built yet and a diagonal wall, increasing the length of the waveguide. This configuration combines the properties of several types of acoustic design. Accumulated acoustic energy radiated through the slit channel between special support and the base of the housing. Harlech amplifier is perfectly acceptable load: the average absolute value of the input impedance of 13.1 ohms nominal - 6.3 ohms, the standard deviation of +/- 4,9 ohms, maximum (70 Hz) 24.4 ohms; frequency bands section - 2.5 kHz. You can connect the schemes biwiring and bi-amping. Amplifier power range of 25-150 watts. Sensitivity, according to our data, the low (84 dB). The field in the horizontal plane is sufficiently homogeneous. One of the advantages of traditional products Castle Acoustics, inherent and Harlech, is the excellent quality of finish of the natural veneer. In this case, the firm offers a variety of coatings. Dimensions of the speaker - 200x940x320 mm.
Connoisseur77
Number of posts : 161
Registration date : 2015-04-26
